928S Shifting Problem.
My 1986 928S has developed a shifting problem.
Occasionally when downshifting from 4th to 3rd, the shifter pulls back and becomes very sloppy. The car remains in 4th gear and it won't let me select any other gear.
Eventually with some wiggling, pulling up and pushing down on the shifter, I am able to find the gears again but sometimes it takes several minutes.
I consider this a dangerous situation as it is quite unnerving to be stuck in 4th gear coming off the freeway. The problem has also happened when shifting from 1st to reverse when parked.
Any thoughts on this issue would be greatly appreciated. I want to drive my car without worries. Thank you,
Old 07-28-2012, 06:15 AM
Kool
AirtekHVAC's Avatar
Front shift rod ball cup? Rear shift linkage? Not sure, as mine is a 78, and I don't know what might be different on the 86
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 07-28-2012, 08:52 AM
Spin-Master's Avatar
If you are doing the work yourself, I would suggest replacing both the front shift ball cup and the rear shift linkage coupler (looks like a universal joint) since the parts are relatively cheap and would make your cars shifting feel much better. I did both on my 911 a few years back and the shifting difference was like night and day. No more "mystery shifter".
LG
1978 911 Coupe Cashmier Beige/Brown
1987 928S4 White/Red
Old 07-29-2012, 01:27 PM
Kyle C
Definitely sounds like front shift rod plastic cup deterioration. Happened to me on several occasions. Replaced the plastic cup in the front shift rod, and installed delrin bushings in the rear coupler. Definitely worth the effort/money, the shifter is very tight and precise now.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 07-29-2012, 07:19 PM
