-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Odometer and tripometer not working (http://forums.pelicanparts.com/porsche-928-technical-forum/692657-odometer-tripometer-not-working.html)
Mpierick 08-04-2012 07:50 PM
I removed the instrument cluster to fix the odometer, thinking it is the gear that has broken apart. I purchased one from Roger. Well, I dug into the cluster and all the gears are intact. Any ideas what else it could be?
Thanks Mike P
Mpierick 08-05-2012 09:35 AM
Can the servo motor be benched tested?
Thanks. Mike P
MPDano 08-05-2012 11:07 AM
If it's not the gear, then it can be the PCB connectors, PCB itself, grounds, connector in the spare tire area or the sensor mounted on the rear diff.
tmpusfugit 08-05-2012 11:18 AM
Thanks. Mike P
I think it is a stepper motor, not a servo motor, so I don't think you can easily test it with things found in our normal toolboxes, what ever that might be.
However, you might want to check for binding in the worm gear to the driven gear, as well as the odometer or trip indicators binding up and locking of the mechanism. In one case I discovered the new gear was just a bit bigger than the original gear, but I found that out after I reinstalled the pod and drove a couple of hundred miles....then it stopped. A washer "shim" under the foot of the motor provided enought freedom for the gear mesh and it has worked for 5000 miles since.
Perhaps your gear was replaced by a PO with one of these that binds up, ot it may just have locked up in the indicators themselves....
Mpierick 08-05-2012 12:51 PM
MPDano, Thanks I have cleaned all the grounds in front of the car. I did not think about the rear. I will also check the sensor. When I replaced the filter and gasket for the transmission I noticed a wire back there that was bare. I fixed it but did not notice where it went. It might be part of the sensor. I am going back under there and check the sensor. Thanks
Tmpusfugit, I can move the worm gear with my finger and move it enough to change the mileage. I don't know if my finger get a little grease on it but, it feels like it binds a little.
Can you put a 9v battery on the leads to see if it turns or will that burn everything up?
Thanks for the help. Mike P
Mrmerlin 08-05-2012 09:54 PM
if you take a look at the gear that was replaced you may find one of the teeth has a little bit extra flash from the molding process,
The cure is to trim the gear teeth, I have found this issue on a few replacements.
The extra flash causes the gear to have hi spot and thus bind and stop the mechanism from turning
Otherwise the motor for the speedo could be bad disconnect the wires and test it with a 9volt battery if it wont turn then you found the issue
Mpierick 08-06-2012 05:13 PM
I have disconnected the motor. It has two green and one yellow wire. I am not too good on the electrical side. How do I test the motor?
I took a resistance meter and I am getting a reading with touching all three leads. Is that an indication the motor is bad?
Also, if the motor is bad, are there motors available?
Thanks. Mike P
19psi 08-06-2012 06:29 PM
Not to threadjack, but is gear failure inevitable on these cars? Is this something I should add to my next order just to have on hand?
