Rear Wiper Motor Problem
Hello
1988 S4, MY rear wiper does not stop running, had to pull the fuse. Any ideas on what's wrong. |
relay.
I would also check that the switch is releasing
or the switch cover melts and then sticks when pushed,
or the switch panel has gotten deformed from leaning on it, and its binding the edge of the rocker holding it down same goes for the window switches |
I have to "disengage" the window switches on Marvin ever time I use them. Need to look into that soon.
| All times are GMT -8. The time now is 09:33 AM. |
