82 928 euro atm/lsd
fuel sender wire diagram help
fuel guage is not working and just want to make sure the three wires are in the right pin holes. i put power to the purple wire and the needle showed a reading . the plug has numbers and the sender has three letters w t g . does anyone know which numbers match what letters.
1979 928 5 speed 90k
Old 09-06-2012, 02:57 PM
928: Serial Enabler
Yellow/black to W, which is terminal 1, traveling to CE panel via plug T terminal 4.
Violet/black to G. which is terminal 2, traveling to CE panel via plug T terminal 3.
Brown (31) is ground. (see the upside down T symbol on the male plug at sender?)
Looks like it matches with terminal 3 of sender
Ground is located on 10mm bolt behind pass side quarter panel.
Gotta have wiring diagrams to have a fighting chance on these.
Old 09-06-2012, 04:05 PM
