curtisr
curtisr's Avatar
Wing measurement please
I am putting a rear spoiler onto an '82 hatch and am hoping someone could send me a measurement. I would like to know what the distance is from the top of the hatch to the first hole.
Right or wrong, I really think the 928 was born to have a one-piece rear wing. And now I have one.
Thanks everyone.
Old 09-20-2012, 04:04 PM
Spin-Master's Avatar
The measurement down to the first bolt is 43-1/4 inches. The think that will give you problems is that the hatch for 87 and up cars has an indentation for the mounting hardware on the underside. I saw a write-up somewhere with pictures that someone did for installing a wing on early year cars.
LG
1978 911 Coupe Cashmier Beige/Brown
1987 928S4 White/Red
Old 09-21-2012, 03:49 PM
Fixer's Avatar
I read that Porsche engineers once said that a wing on a 928 was unnecessary.
Has anyone else read that?
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 09-21-2012, 05:26 PM
Pete R's Avatar
The measurements may only work for a stock wing. Some aftermarkets dimensions vary. You will have to cut a hole to the inside camber of the hatch to mount the bolts if you have a non S4 hatch.
You can also measure the long way between the mounting locations on the wing. If you transfer that dimension to the hatch it will only fit 1 place as the hatch is tapered
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-21-2012, 06:22 PM
I've heard that the wing is not necessary also. The thing you have to remember is that any appendage on a car will have effect on the car: wings, spoilers, tails, etc. They are generally intended to create downforce to help the car stick to the road, and also used to stabilize the car. Most wings, spoilers and tails will do just that but at a cost....lowering the top end of a car because to be effective, they will create drag and if not installed properly (mis-aligned), they will make the car feel unstable. The effect isn't really noticable until you reach speeds above the legal speed limit. In the case of my 911, on a windy day the tail can make the back of the car wiggle a bit as it approaches triple digits but the car is only 2600 pounds.....Just food-for-thought.
LG
Old 09-21-2012, 09:13 PM
laneyamps's Avatar
I too, have read that about the rear wing on a 928..."Not really needed"....But, I gotta admit...The S4 wing looks pretty bad ass! LOL
84' 928S Black/Black
Old 09-21-2012, 09:17 PM
curtisr
curtisr's Avatar
Thank you so much for this! And I will search-out the article. Thanks again.
Roger
Old 09-22-2012, 07:42 AM
curtisr
curtisr's Avatar
I seem to have the real-deal.
I was a bit hesitant to take the drill to the car as I have been doing the measurements as you've described them all the while checking for horizontal alignment and vertical alignment (over the back end); hence the measurement request.
you have to remember is that any appendage on a car will have effect on the car: wings, spoilers, tails, etc. ...Just food-for-thought.
Agreed and the effect I am looking for is a pleasant aesthetic. :-) Getting the proper level won't be an issue; however, it may require a small collar to hide any unusual canting. I will post a pic when done.
See above...lol!!! Yes, and I have spent a year or so looking at the car trying to visualize the result and have decided this is a must-have.
Thanks everybody.
Old 09-22-2012, 07:54 AM
Just remember to take your time and get it right. And think ahead of how you will do it before you even touch the hatch because once the drill bit touches the hatch you will be at the "point-of-no-return". Search for that article on doing it. MPDano might have it on his post at the top of this forum.
LG
Old 09-22-2012, 02:53 PM
Fixer's Avatar
Be Sure To Use A Center Punch (machinists tool to mark the hole location) where you plan to drill so you don't skip the bit down the hatch an inch!
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Old 09-22-2012, 03:39 PM
Here is the posting on MPDano's thread. It starts at post #65.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CCgQrAIoATAA&url=http%3A%2F%2Fforums.pelicanparts.com%2Fporsche-928-technical-forum%2F607208-most-common-928-issues-fixes-4.html&ei=mz9eUOHOKISZqQGOqIGYAQ&usg=AFQjCNGDdqxv9yOuW3KJ5B7e8fkYnqcA_g&sig2=yoknWp1Y9WY_tbSthvsFUw
LG
Old 09-22-2012, 03:48 PM
curtisr
curtisr's Avatar
Roger that!
Old 09-23-2012, 07:08 AM
curtisr
curtisr's Avatar
I have looked at pictures, studied my Porsche books (lol), bounced the idea off of friends and aficionados alike, sat in the garage and outside with a 'real' 928 spoiler in-place. Ditched my first spoiler as it wasn't original, slept on it, blah, blah, blah.... And last night with centre punch in hand I started the dirty deed.
The bottom line? I'll be glad I have it.
Old 09-23-2012, 07:15 AM
curtisr
curtisr's Avatar
Wow. This is just what I needed!. Thanks for the post!
A question to Leo: did you fill the cutout? I was thinking of using some clear silicone or Bondo's not-so-permanent filler that comes out of a mousse-like container, dries semi-clear and can be easily removed--usually in one piece.
Old 09-23-2012, 07:22 AM
Kool
AirtekHVAC's Avatar
I want a wing on my OB!!!!!
Looks great!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 09-23-2012, 04:06 PM
curtisr
curtisr's Avatar
It's on and looks great. So good, in fact, that my wife said that she would like to take it out for a ride and did. :-)
Old 09-23-2012, 05:47 PM
curtisr
curtisr's Avatar
I used the 43 1/4" meaurement and, as a result, the bolt heads are inside the frame. And at the risk of becoming persona non grata, the result is the same as the S4 when you drop a plumb bob from the trailing edge..
The above link is great! Nice work. Given my car is silver in colour,however, I think I may simply seal with metal foil tape. For now anyways.
Old 09-23-2012, 07:09 PM
That's great. The measurement I gave you was from my S4. They make plugs of various sizes which would make it look original to the ones that don't know any better. Post some pics before the tape. You might get some ideas on what would work for cosmetic plugging & sealing.
LG
Old 09-24-2012, 04:36 PM
curtisr
curtisr's Avatar
The key to any plug or seal is being temporarily permanent. Or is that permanently temporary?! Regardless, the temporary solution for now is permenently temporary foil tape (on silver). It looks OK but, not as good as this:
Ooops, just noticed the part of posting a pic of the holes. Wilco a bit later.
Old 09-25-2012, 05:56 PM
