-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   What I've fixed (http://forums.pelicanparts.com/porsche-928-technical-forum/707257-what-ive-fixed.html)
DZGunner 09-20-2012 07:08 PM
What I've fixed
Re-wired all audio components to get them into working condition
Fixed too many vacuum leaks, now using all silicone vacuum lines
Removed the unused Smog pump pipes to free up room
Replaced faulty/punctured intake hoses
Replaced Idle Stabilizer
Replaced 2 water heater Gaskets
Fixed multiple Coolant leaks due to PO's paint job
Replaced Thermostat with 75 degrees C (took out 83C)
Replaced Broken temp switch (fans now work)
Changed fuel filter and some old fuel lines connecting to it
removed rust/painted fuel filter cover
Replaced fuel sending unit top seal
Replaced fuel filler grommet
Created rear left wheel well to prevent particles from entering
Stopped transmission leak (had a shop do it unfortunately)
Replaced both front wheel well covers (previous ones were missing)
Replaced faulty window switch
Fixed Driver seat adjusting buttons (at the expense of the passenger side) so i can adjust my seat now
Removed all the PO's crappy aftermarket LED clusters he duck taped all over the inside
replaced many various faulty / missing screws all over the interior and exterior
Current project:
Converting instrument cluster to LED's
To do list:
Alternator
Wheel bearings/suspension
oil change/gasket/filter
motor mounts
fuel pump
brake job
Future:
Nice expensive paint job
Super charger/ after market headers
Danglerb 09-20-2012 07:39 PM
Wow, you had a busy day, good luck on the rest tomorrow.
Gonzotiki_666 09-21-2012 09:54 PM
I like this. I'm only a quarter of the way through my to do list.
AirtekHVAC 09-22-2012 04:41 AM
oh my...wow....busy boy!
I hope to get back on to my Looooooooooong list soon....
