EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
Fuel Accumulator Bypass?
Okay, so after walking past the 928 for about a year everyday, i got the itch to fix and and drive it. Can i bypass the fuel accumulator by getting some high pressure fuel line and clamps, joining these two things together?
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 10-08-2012, 12:22 AM
JK McDonald's Avatar
Accumulator -
Hey EIP, Anything is possible - it is just not that everything is necessarily a good idea. For one thing the accumulator stores the car’s running fuel pressure which is used to help restart the engine. Also, since you have removed the accumulator - the fuel lines you might install as a jumper around the accumulator’s location would have to be done properly to avoid any potential leaks, failures and/or fires. There is nothing like a Porsche on fire to draw the attention of a crowd along the highway. Personally I’d recommend that you simply leave the accumulator in place.
Although not recommended, you can delay the replacement of the accumulator and not have to deal with the typical “hard restart” issues if you add a toggle switch to provide an additional ground to the fuel pump relay. With the key on - the new toggle switch would be closed for a few moments prior to turning the ignition switch to start. This would manually cause the fuel pump to pressurize the injectors and simulate the residual fuel pressure normally held in the accumulator.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 10-08-2012, 06:47 AM
Northern
MainePorsche's Avatar
Originally Posted by JK McDonald View Post
Hey EIP, Anything is possible - it is just not that everything is necessarily a good idea. For one thing the accumulator stores the car’s running fuel pressure which is used to help restart the engine. Also, since you have removed the accumulator - the fuel lines you might install as a jumper around the accumulator’s location would have to be done properly to avoid any potential leaks, failures and/or fires. There is nothing like a Porsche on fire to draw the attention of a crowd along the highway. Personally I’d recommend that you simply leave the accumulator in place...
Good Luck, Michael
Well put.
87 928 S4 Indischrot - Siede Grau - Schwarz Leder - Unberührten Automatikgetriebe
Old 10-08-2012, 10:49 AM
