Kalspeed's Avatar
AFM to housing fitment
Hi guys,
I was wondering how the AFM unit in my 1982 is supposed to fit inside the large 0-ring in the U housing. Looks like it should snug inside the throat with the 0-ring sealing it.
I can't get it to fit, sits on top of the o-ring, and even the filter housing when secured, the AFM isn't inside the o-ring.
Any tricks to getting this right?
Old 09-22-2012, 03:37 PM
I'm assuming you got the new o-ring from one of the vendors. how does the o-ring feel inside the notch its supposed to be in? It should be pretty hard to get out once seated properly unless you have a tiny flathead to pry it out. otherwise there might be some remnants of an older seal cramping it.
I'm not aware of any size differences in the afm to u-joint for l-jet cars.
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 09-22-2012, 04:01 PM
Kalspeed's Avatar
Yup, it's a new o-ring and it fits well in the groove. Seems the "nipple" part of the AFM won't snug into the o-ring. Even with the lower air box removed, I can't get it to seal. Seems to want to only sit on the o-ring.
Old 09-22-2012, 04:07 PM
Kyle C
I was surprised at how tight a fit new AFM O-rings are, I gave mine a light coat of motor oil and then installed the AFM without the airbox attached to get it to seat properly. Took a lot of pressure and twisting back and forth.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 09-23-2012, 06:08 AM
i forgot about that. i did use sillicone lube spray on mine as well before inserting it, it is quite the tight fit. first time you really need to push it in.
My Car:
Old 09-23-2012, 02:18 PM
Kalspeed's Avatar
Thanks...would account I guess for a vacuum issue I have had
Old 09-23-2012, 03:54 PM
