80 928
4.5 to 4.7 swap
Does anyone know if I will run into any issues running my 4.5 L jetronic FI, and 4.5 flywheel on the 4.7 engine I'm building?
I'm using euro cams, tubular headers thru a 3" exhaust system with a flowmaster muffler, K&N air filter, stock C.R., total ignition timing to be set at 28deg.
Any estimates on power output?
-Kerry
Old 09-26-2012, 09:58 AM
Pete R's Avatar
I did the swap but used CIS. The question will be is if there is enough headroom in the L-tronics to read and flow enough gas at high rpms and not lean out.(which I don't know, CIS worked fine)
You'll probably be around 240-250hp
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-26-2012, 11:08 AM
I might be wrong but I thought a 4.7 engine puts out 315hp
Old 09-27-2012, 01:32 AM
Pete R's Avatar
A full 4.7 84-86 Euro with pistons, heads, cams, intake, throttle body ect is only 310. Adding cams and exhaust to a normal US motor won't get all that. Maybe 20hp over the normal 230hp if the engine is fresh. Just a guess really though, don't have dyno #'s
Neon SRT4 track car
Old 09-27-2012, 04:08 AM
80 928
My motor is an '83 4.7 (rated at 234hp). I figured a euro cam, headers, 3" exhaust, no cat, and 5deg increased ignition timing would be worth at least an extra 25 or so h.p., or around 260hp.
Old 09-27-2012, 07:16 AM
Pete R's Avatar
I'd buy that
Neon SRT4 track car
Old 09-27-2012, 08:06 AM
European Shark
riber.bentsen's Avatar
Well, Porsche were always conservative with their performance numbers. Some have measured (late) 4.7 euros at around 340 hp.
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 09-27-2012, 12:05 PM
Xlot's Avatar
Yep - a local manual '85 S2 (4.7L LH2.2) put down 206rwkw (276rwhp) on a Dyno Dynamics machine.
For comparison, that is more than a stock 91GT (267rwhp) and manual 89S4 (260rwhp) both put down on the same machine. And the GT and S4 were both post-intake refresh so had all working sensors etc.
Various manual S4's
Old 09-27-2012, 07:26 PM
