Is there a pod backlight?
Just bought my first 928 and I need to say....;););)
Does the pod have a backlight? I took her down the driveway for a test at 8pm and realized I have NO idea how fast I'm going. It's completely dark. Suggestions? Thanks |
Try the brightness adjuster on the left hand side between the wheel and the fog lamp knob.
#26 below. |
Pics are so fun to look at, please post some for us to see your first 928. Thanks.
Congrats and welcome. |
Welcome, Homer!
Yes, there are lights in the pod, and I'd check the brightness adjuster, (as mentioned)....IF it works! LOL My adjuster doesn't do squat! But, luckily, my pod lights are "on", and on the brightest setting. I'll eventually take it out, and see if I can't clean it up, and get it working... |
Congratulations!
What model year is it? If the dimmer rheostat is bad, you won't get the dash lights to work. If the ashtray light is working when the headlights are turned on, then most likely the dimmer is bad. If the ashtray light does not work it could be the fuse. Hugo |
| All times are GMT -8. The time now is 06:11 PM. |
