Fixer's Avatar
I'd remove the brake pads and caliper bolts without cracking the brake lines and carefully get a good look at the caliper piston seals.
Look at the flexible lines too. If they all look good (not cracked) put everything back and bleed the system and drive the car. Brake lines swell on the inside with age, if they have not been replaced they should be.
Rebuilding calipers is always a good idea as Landseer said if within your ability.
But you did say it stops well..
Matt Mariani BSID, Haverford, Pa Instagram acct: @the_r_institute tel: 267 767 4565
Back date hotrods, design, metal and paint.
Re anodized Fuchs, custom offset, Steel-alloy wheel maker
1968 SWB 912 "Stinger 912R 1680 lbs
1977 911S coupe "Bandit" back date ST 2.9 short stroke 1990 lbs
Old 01-04-2013, 06:04 PM
camo's Avatar
Thanks the fixer, lll start narrowing things down this week (hopefully)
"Weissach" 1982 Porsche 928 auto
Old 01-06-2013, 03:28 PM
Network Native
Danglerb's Avatar
Camo, looking at your sig, 1982 Porsche 928-hellbronze metallic auto , did anybody ever check to see if its a Weissach? They were that body color with a two tone interior.
Old 01-06-2013, 07:28 PM
camo's Avatar
Danglerb, My interior is just ugly brown
Old 01-06-2013, 07:43 PM
camo's Avatar
So, I've noticed my car shifts a little hard, I'm thinking I should get the transmission checked. Is it pretty involved to check the fluid?
Old 01-06-2013, 10:34 PM
Kiln_Red's Avatar
I have seen a few cases where the vac line was either missing or severed for the transmission modulator. Follow the metal vac line at the front of your intake to where it is fastened to the engine at the rear of the right cam tower. Check the condition of the rubber line that attaches to it. You can also adjust the modulator easily. Details are outlined in the WSM.
Checking the fluid is easy. The reservoir is mounted at the right of the transmission case. Kneel down in front of the right rear tire to see it. It is small, so it is easy to overlook as it is usually coated in grease. Here is a good guide for checking the fluid. The Nichols page is a great reference. Bookmark it for the future.
Old 01-06-2013, 11:08 PM
camo's Avatar
Thank you kiln_red! I'll check that tomorrow (hopefully)
Old 01-06-2013, 11:23 PM
European Shark
riber.bentsen's Avatar
Remember to have the car up in temp and running while checking the fluid. Make sure the car is level and have a piece of cloth ready to whipe the reservoir with
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 01-07-2013, 04:20 AM
camo's Avatar
Hey, after doing some searching I am starting to wonder if I might have a Weissach. I doubt it but you never know.
I always thought that mine could do 0-62 faster than 8.5 seconds. If I understand correctly, the Weissach (how do you say that?) does 0-62 in 7.5 sec.
Anyway my interior is similar to this one.
I have the VIN but I dont know where to look it up. If anyone could help, VIN is:WP0JA0927CS821644
Like i said, I doubt it is, but it never hurts to check.
Old 01-15-2013, 09:47 AM
The Weissach was strickly a cosmetic option. The difference in acceleration may be 2 different tests, one of a manual and one an automatic.
http://members.rennlist.com/bigdave/weissach.html
Old 01-15-2013, 11:25 AM
camo's Avatar
Oh ok. I just read that somewhere on the internet.
Old 01-15-2013, 11:27 AM
928: Serial Enabler
If you have pieces of the luggage with the car, it might be important.
Old 01-15-2013, 04:31 PM
camo's Avatar
No I don't have the luggage.. Also there's no crest on the dash.I noticed that's mentioned in the link dougm shared
Old 01-15-2013, 05:04 PM
camo's Avatar
How can I find out if it is a Weissach or not?
Old 01-15-2013, 05:06 PM
stepson's Avatar
Camo,
There were only something like 205 Weissachs made. I believe that it has an option code. Email roger@928sRus. He has a couple of them and can run your VIN # to check.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 01-16-2013, 04:50 PM
Network Native
Danglerb's Avatar
Roger might know, 200 or so planned, but actually more than 250 going by vin I think found, maybe as high as 275. Option code is
M462 928 - Special Model 82 "WEISSACH" - Hellbronze Metallic w/Leather Medium Brown Int.
Old 01-16-2013, 09:09 PM
camo's Avatar
Great thanks guys!
Old 01-16-2013, 09:13 PM
stepson's Avatar
Well there you go!! I knew there was an option code for it, but I didn't know the number. I figured one of the resident gurus would know and speak up.
So Camo, if your car has that option, then it is definitely a Weissach.
Thanks Danglerb.
Old 01-17-2013, 07:47 AM
camo's Avatar
I looked in my warranty manual and under optional equipment. The option number danglerb gave is not listed
Old 01-17-2013, 03:50 PM
camo's Avatar
According to Roger, I DO have a Weissach. I picked up a Weissach for $2,500
Now if only I had the luggage...
Old 01-21-2013, 01:29 PM
