1985 Porsche 928s
32v intake manifold removal
How do I remove the intake manifold on a 1985 32v? I have the side "boxes" off but need to know how to remove the central plenum.
Thanks in advance.
Old 12-29-2012, 12:52 PM
Each intake manifold is held on by two bolts into the head. There are 4 manifolds. The bolts are 8mm thread. 13mm head if I remember correctly. The big center intake is just clamped on the throttle housing via a rubber sleeve like on the side boxes(distributor housing in the parts manual). There are two intake gaskets for the 4 intake manifolds that you will have to replace. With the intake removed it is easy to pull your injectors and have them cleaned. I strongly urge you to have the injectors professionally cleaned. If you have no one local many people on the board have used Witchhunter. 20-25 dollars per injector. It will save you many running issues.
69 911 2.3Ez
85 928S
Old 12-30-2012, 06:59 AM
1985 Porsche 928s
Thanks, I'll take another look.
Old 12-30-2012, 10:33 PM
Petie3rd
Mrmerlin's Avatar
before you remove the intake,
get an air gun and blow out the dirt from the around the injectors,
and the sides of the manifold.
this so dirt wont fall into the cylinders
Old 12-31-2012, 09:03 AM
1985 Porsche 928s
Now that I have the fuel rails out of the way it's pretty clear - thanks guys.
Old 01-03-2013, 08:33 AM
