1985 Porsche 928s
Carbon in the intake
Upon disassembling my 1985 32v engine (with 65k miles) I notice that there's quite a lot of crusty carbon / soot on the inside of the intake tubes around where the fuel injector is inserted. This extends a few inches up into the intake tubes. Is this normal? Does it maybe indicate a valve wear / timing issue? I plan to do a leak-down test but was curious to know if this was expected.
Old 01-17-2013, 11:53 AM
Fixer's Avatar
I replaced my plugs last weekend and looking down in at the pistons i saw a decent amount of carbon deposit, plugs looked normal. I also have 65k miles. If you had pre mature valve wear you'd see it out back. I think that is normal but should be cleaned.
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 01-17-2013, 12:31 PM
1985 Porsche 928s
OK, thanks Fixer. I'll see what it looks like once I dig a little deeper. I had planned to do a lot more with the engine removed but I might scale it back a bit so I can have it on the road for summer.
Old 01-17-2013, 02:28 PM
Fixer's Avatar
Why are you taking it apart?
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Old 01-17-2013, 02:43 PM
1985 Porsche 928s
The main reason for taking the engine out & apart is to fix a blown head gasket. While I'm in there I'll do some other things so I don't have to take it out again for a while (famous last words).
The car is in great shape (2 owners) but the history is a bit patchy. The Porsche garage who inspected it said it was in great shape and ran well. The TB and WP are a given and I'll replace both head gaskets and oil pan seal at the same time, plus have a good old look around while I'm about it.
Old 01-17-2013, 02:52 PM
Fixer's Avatar
Didn't know, guess you should have the heads and valves looked over by a machine shop anyway.
Do you know why the head gasket went? I would wonder if it had anything to do with the head studs. There is probably some good threads to read on the head studs/bolts
I'd make sure that is right.
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Old 01-17-2013, 03:19 PM
1985 Porsche 928s
The PDI mechanic diagnosed head gasket due to a small pool of oil under the car after it was run for 20 minutes. What I did find, though, was quite a pool of oil in the "valley" - between the banks, possibly due (I think) to the breather from the RHS crank cover to the oil filler having completely disintegrated.
I have read some interesting threads on head bolts - a little apprehensive now.
Old 01-17-2013, 04:45 PM
Network Native
Danglerb's Avatar
I think I would always want new guides and seals if the heads come off.
AFAIK oil is almost never the issue with 928 head gaskets, always the coolant.
Old 01-18-2013, 12:06 AM
1985 Porsche 928s
Yeah, that was my feeling too. Anyways, after having not run for a while, it will be good to get in there and check around. At least then I can feel confident that it's all good.
Old 01-18-2013, 07:52 AM
inventor
porken's Avatar
Most likely a bad rear cam seal...
Carbon on the last few inches of the intake runners is normal.
It's fuel (reversion) mixed with oil vapor (PCV) which is then baked on.
Clean/grind it out. Gasket match while you are at it. Will give a few more HP.
(Leave a slightly rough surface.)
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 01-18-2013, 08:50 AM
