Front Cam Seal/O-Ring Question
I'm replacing front cam seals and o-rings on my 83 928. The passenger side flange came off with no problems. I wanted to see if the drivers side flange comes off in the same manner or, is there anything to do differently since the distributor is on that side? The workshop manual did not cover this part well.
Thanks, Peter |
Just as easy except I had to pull the distributor on my my 4.5. I may have also needed to unbolt and move the PS reservoir to the side.
| All times are GMT -8. The time now is 08:36 AM. |
