Auto Transmission SLIPS badly at take off
Have had the trans and TT out for need TT bearings and Torque converter bearings. Also resealed the trans pump. After first try the trans slipped at take off but at higher speeds did well and reverse was great. Second try I took trans to a shop and THEY RESEALED the pump as I had damaged one of the seals when I did it. I reinstalled the trans today ( second time ) and the same problem is there...if not worse.
I am doing a lot of readings and it sounds like this is what happens when the B2 piston goes. Could this be bad timing as I had NO issue before I resealed the first time. ( I always look at what I FIXED LAST ) I KNOW the fluid level is good. Will take it in tomorrow to check pressure at modulater. Any input would be helpful as I am at a loss and not sure anyone around here knows anything about this car. Attached is a video where I am tryng to drive up the steep driveway from stop and it FINALLY makes it but it takes awhile. https://www.youtube.com/watch?v=fz9qS0u-nRg
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) Last edited by Dean_Fuller; 02-18-2013 at 07:52 AM.. |
Dean,
I would pick Greg Brown's brain on this. I'd offer a guess of my own but transmissions ain't my thing. I hope you get your shark back in good health soon. |
Is the trans fluid at proper level when running?
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Yes...fluid is full when running in park.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
Hello Dean.
I had the exact same problem in my Auto 88. It is the B2 piston, 99% sure. I did the work myself which was over 9 years ago. Check out Rennlist and look up -Steve Cattenaeo- My posts on this fix may still be there as well as,-mpesik. There is also a kit which Benz supplies for a first gear start in which I installed. I used Viton seals as they are much much more durable than Factory.
Formerly from ratslist. AMG E 55..2002. Lotus Esprit SE. 1990 Last edited by mikeesik; 02-18-2013 at 06:46 PM.. |
Sounds kind of like a problem I had with my transmission at one point. You can read here what I found wrong and did. Transmission Drama
86 928S 98 Saab 900S Turbo |
Kool
Dean, any luck?
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Kool
Dtool, I read your thread...very cool man...you made it sound / look simple...maybe one of my next ones (lol) will be an auto...
