-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   928s odometer question (http://forums.pelicanparts.com/porsche-928-technical-forum/736252-928s-odometer-question.html)
dns83928s 02-26-2013 10:12 AM
my 83' 928s odometer doesnt work, the speedo works and cruise control but not the odometer, is this a gear in the tranny or on the odometer itself, what is the best way to determined which end my problem is at- thanks doug
Pete R 02-26-2013 10:27 AM
Most likely it's the gear in the speedo. It's all electric ,there's no gear in the tranny just a sensor. If the speedo is working it has all the required input, it is something internal in the speedo unit
Kiln_Red 02-27-2013 12:49 AM
The gear in the odometer deteriorates with age. Just get a replacement from Roger and follow Dwayne's writeup to install it. Pretty straightforward.
Here is the link to his page.
MPDano 02-27-2013 04:18 AM
Yup, this will be your issue. The gear disintegrates like an old rubber band does. What's weird is that it's the only gear in there that does. Be careful when you remove the Instrument Cluster as 30 year old plastic is very brittle.
