Cam Gear Install Question
I replaced all the front cam seals and o-rings but do not remember how far the cam gear went on the camshaft. Does this look right? Seems like the gear should fit flush with the end of the cam. I have had it apart too long and don't remember!
Thanks, Pete
1983 Porsche 928s US Auto |
1985 Porsche 928s
I think it goes on way further than that. I have mine apart right now so I'll see if I can find a picture from the disassembly.
Thanks!
Pete
Petie3rd
once you put the bolt in the cam it will pull it forward ,
the cam will slide backwards some without the cam pulley and bolt in place and if its pushed.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
European Shark
Sure it's not flipped?
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
Petie3rd
Ahh from the picture the cam pulley does appear to be flipped around ,
the faces are the same but the hash mark should be facing the engine
European Shark
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". Last edited by riber.bentsen; 05-08-2013 at 09:50 AM.. |
I checked and the part number and MWU mark are visible from the outside. The timing notch on the teeth are on the side facing the engine. I think this means the gear is mounted correctly. At this point I will pull the flange and re-check assembly order. If nothing is out of place, should I torque it to spec and see if goes into place? Thanks to all who have answered.
Pete
European Shark
If the timing notch is on the inside, it is indeed mounted correctly. Strange?
I seem to remember mine sitting like that. If it sat flush, with all the tolerances of the parts in there, it could actually bottom out the washer on the cam and not the gear which would leave it all loose.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
I just assembled mine this weekend. I also see the slight protrusion of the gear past the cam. I did some research, and I *believe* that this is correct.
-- David 1981 928 US 5spd Red |
Please tell me if you find this next suggestion helpful!
When I first did this a few months ago, I had SERIOUS issues with the cam tower bolts that are INSIDE the housing. I kept dropping them and having to remove the cam tower to get them out. After a couple of tries, I came up with an idea that I have not seen anywhere else. The idea is to make a sleeve out of a 2" strip from a 3x5 note card (paper size 2"x3"), insert the sleeve into the cam tower bolt hole, and then feed the bolt through that sleeve. This worked great for me and made it trivial to get the bolts into the holes without any drama or stress. A picture of the cam tower with the card stock sleeves: ![]() Unfortunately, with all of the handling that I did the first time around, the gasket slipped and I ended up doing it all over again. The engine is almost fully back together & hopefully I didn't screw anything else up this time. However, installing the internal cam tower bolts was a snap when using the paper sleeves. I found that you need to cut the 3x5 card into strips that are about 2x3 - the card stock cannot overlap in the tower bolt hole or the bolt/washer will not fit through easily. I left a small gap in the top and rounded the paper using my pinky finger before inserting the bolt. Good luck!
You could have also filled the allen hole in the bolt with thick grease before you insert the driver, the suction will hold it on. Do the hard bolts first incase you knock it off on the hole on the way in. I've had good luck removing fallen in bolts with a small telescoping tool with a tiny magnet fixed to the end.
Network Native
I use Wiha magicring long shaft hex bits. The tip has a ring like on a impact wrench to grip and hold the inside of the fastener.
