-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   shift linkage adjust (http://forums.pelicanparts.com/porsche-928-technical-forum/751018-shift-linkage-adjust.html)
rockclone 05-20-2013 10:05 AM
My car pops out of 1,3,5 all down gears up gears aree fine,what could it be ???? thank you ,,,84 928 s manual 5 speed wont stay in gears pops out only 1,3,5 though reverse,2,4 r fine work well. ????????:confused:
Mrmerlin 05-20-2013 03:27 PM
you need to readjust the shifter coupler
with the shifter n neutral have a helper hold it centered while you loosen the 13mm bolt that clamps the collsr on the shift rod of the transmission then re tighten the bolt .
IF the bushings are worn then the bushings neeed to be swapped out
rockclone 05-20-2013 03:52 PM
shift linkage
is it done from inside car? it should be under boot or ? do i remove the center console? i really appreciate all the help thanks guys !!!!!
rockclone 05-24-2013 06:05 PM
I see bad shift linkage!!!!!!!!!!!!!
I found out i have bad shift linkage bushingings whats the best way to get to them to replace all ? From under or from inside
Mrmerlin 05-24-2013 07:37 PM
the rear shift coupler is adjusted or replaced from under the car jack it up and support it on atleast 2 jackstands,
the coupler is just on top of the rear mating surface of the torque tube where it mates to the transaxle an allen setscrew holds one end and the other end is held with a 13mm bolt/nut
