Kool
Differential Question
Ok, quickie for you guys...I know this is stated in several threads, but my OCD wont let me skip through them to find what I need, I just read them all, never focusing on finding my answer.....
There are (3) plugs on the diff, (1) on rear-bottom, drain....(1) on rear top...fill, and (1) on the opposite end, drain....correct? my question, is there only (1) fill port? The reason I ask, the fluid from the back drain seemed thicker, like gear oil should be, the fluid from the front drain seemed much thinner-more fluid.....does that make sense? Are they different chambers? Please enlighten me....I know probably a stupid question, but I just drained it all out, and want to refill tomorrow evening....I have the fluid, and know that it holds 4 qts. (well at least the back does?) Signed...confused.... Thanks!
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
928 Junkie
Hey buddy,
You are correct so far as the ports go, however I think you need to drain the torque tube while you are doing that and it is 7 to 8 total qts. The fill port is the upper rear and will fill all chambers.
Brian Phillips 1979 928 , 5-speed, cork interior 1982 Euro S 5-speed project 1985 928S, auto(sold)1978 Euro 5-speed (found another home)1983 928 s 5 sp short shifter black/black (sold)1982 928 auto (sold) |
Kool
I have about 10 qts., so no prob there....drain the TT? From where? I thought it was just a shaft in a tube with bearings?
Petie3rd
for your 5 speed there are 2 drains and one fill plug,
the drains are at the front and rear of the transaxle , the fill is from the rear middle plug, make sure you can remove the fill plug first. it takes about 4 qts to fill the trans axle. I think the other poster was trying to say drain the torque converter not the TT, since your clutch doesnt hold any fluid dont worry about draining it
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Trust me!! There is only one fill plug. The one you found. Do not, what ever you do take the bolt in the side if the case out. Trust me lol
Kool
Lol! Thanks! I read your post! Sage advice!
Thanks Merlin. Could have been just me, but the fluids from each end seemed to have a different consistency, which prompted my question. It was getting dark tho' and I did not have the lights on.... Oh, I did make sure the fill plug came out first. Thanks again! Last edited by AirtekHVAC; 05-22-2013 at 02:53 PM.. |
One of the plugs is located at a lower point so it gets more of the "sludge" from the bottom of the case which may be why they appeared to be different fluids.
Kool
That's what I was thunking.....
