Where is fuse box? With relays?
On my 1984 928 where is fuse box located? It also has relays in it as well,,
Behind a flip-up wooden hatch at passenger feet. On interior firewall.
Be careful what you do inside there. Need wiring diagrams to troublshoot. Post really good overall pictures and a set of closeups and we can give input. Include closeups of the wiring coming out of the plugs along bottom row. Extremely useful in diagnosis. Will need to remove the upper and lower wooden covers to get good pictures. |
Crazy Germans. Lol
Pull the carpet from the passenger footwell. You will see the black plywood board at the front of the footwell under the shelf. Pul that up and it will swing up. Theres the fuse panel. Check MPDano's common fixes for cleaning the fuse panel and checking grounds.
Damn, look at the response times will ya. All over it!
Fuses and grounds, yes. But be sure to go through the wires on the plugs with a finetoothed comb. Amazing as telltales of havic in the electrical system that you might not realize otherwise for a while. |
whats mpdanos
One of the Gurus here. He started the "common fixes" thread...its at the top of the forums topic list.
all fixed ,,,,it all came down to the battery was junk!!!!!!!
928's go through batteries like pancakes. Almost all 928's have some kind of drain, current draw long after turning off the key, and full discharge or even deep discharge ruins most batteries quickly. After years of dealing with it, I put disconnect switches on both of mine.
| All times are GMT -8. The time now is 08:11 AM. |
