No Right Tail Light Or Marker Light,,
I have no right tail light or marker light for side in back on passenger side on my 84 porsche 928s,,any ideas any one?????? Thanks
Old 06-13-2013, 03:24 PM
Petie3rd
Mrmerlin's Avatar
check the fuse, and the bulbs
then the connections at the rear of the corners inside the hatch,
look for a small white connector on the hatch floor this is for the side marker light,
also inspect the connection points behind the liner for the rear tail lights
also check the grounds on the floor of the hatch and the spare tire well and behind the rear quarter liners
Old 06-13-2013, 05:00 PM
JK McDonald's Avatar
Lamp Control Unit -
Hey Rockclone, Perhaps your problem is in the Lamp Control/Monitor Unit that tests and distributes all the running, marker, brake, etc.... lights. The internal circuitry of this small silver box checks for burned out bulbs, brake pads and other errors to turn on the dash warning alarm. It is located behind the kick panel by the drivers left foot.
Mrmerlin probably knows more about it's proper operation but one time I chased a brake pad thickness warning light problem around for a few days before discovering a poor wiring connection coming out of the lamp control unit. The PO had just half halfheartedly (halfassed) twisted some wires together instead of soldering the connection properly. If the circuitry at the rear quarter panel checks out - this may be worth a look.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 06-18-2013, 02:01 PM
lights
i noticed the right side flashes faster then the right side,,, one min it works next min it don't,,its crazy maybe flasher ?
Old 06-18-2013, 07:04 PM
Petie3rd
Mrmerlin's Avatar
probably a bulb connection,
the flasher relays are pretty robust,
but its easy enough to swap
Old 06-18-2013, 08:17 PM
