Delawrence's Avatar
Porsche Crest What are the two brown wires on the LH plug?
I am wondering if anyone knows what the two brown wires hanging from the plug on the LH computer and what happens when you connect them? In this photo they are hanging in the upper right with tape on them, mine had no tape
Old 06-25-2013, 04:11 PM
Pete R's Avatar
the brown are usually grounds
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-25-2013, 07:09 PM
Network Native
Danglerb's Avatar
I'm thinking its low octane fuel loop, takes out some timing, but not sure.
Old 06-25-2013, 09:31 PM
Delawrence's Avatar
Thanks, Iv confirmed they are for low octane
Old 06-26-2013, 03:23 PM
inventor
porken's Avatar
The green wires on the EZ harness short the air temp sensor input - making it appear as if the airbox temp is very high - retarding by 3°.
The brown wires on the LH harness tells the LH to change one of the O2 loop pattern maps to a slightly different one.
You might be able to see the difference if you log with a WBO2, but it's not something you'd be able to feel driving.
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 06-26-2013, 11:21 PM
Delawrence's Avatar
So under normal conditions is it better to have the green ones disconnected? When I got the car they were already connected, and I was having high idle problems. I was checking the fuses the other day and checking the readings from the temp 2 sensor, noticed the brown wires hanging and connected them, after doing these things the car will not start anymore, I put a new temp sensor in there re disconnected the brown wires and still wont start up ( it ran before doing this )
Old 06-27-2013, 06:54 AM
A Wrench
SeanR's Avatar
Yep, leave them disconnected. I find this a lot, where people automatically assume that unhooked wires are a bad thing.
'88 Supercharged and lots of other fun stuff.
Old 06-28-2013, 05:42 AM
Delawrence's Avatar
Thanks Sean, The car Im resurrecting was worked on by people who should have never tried fixing it, Iv been a mechanic for decades but this is my first Porsche so its a learning experience, Iv finally gotten my idle to 1000rpm after its warm, was 1200. Next im going to see what readings I get from the MAF, and adjust it if they'r out of spec
Old 06-29-2013, 07:49 AM
Tags
brown wires , lh computer brown wires
