Crumpler's Avatar
Timing Belt Tension 1986.5
Hey Guys, first timing belt DIY.
Belt and water pump done by reliable shop 4 years prior.
PO had belt re-tensioned after that install.
I've put about 8K on the car since.
I have gotten three belt tension warnings: one at high RPM shift several months ago and two recently at idle (one warm and one cold).
I was going to step up and change the belt anyway, etc. I've got parts on the way but I wanted to check tension while I'm waiting. First question: do the belts continue to loosen as you put more miles on them? Can you just re-tension if belt in good condition?
Most walk-throughs are either for 16V or S4, but I've got access to check my tension.
I started to crank to TDC (clockwise) and initially it moved easily, then significant resistance. That's when I put the wrench down. I was only using 1/2 inch socket with small breaker bar.
Second question: is this normal, can I fubar if I just go for it with 3/4 and cheater, and would it turn easier without spark plugs and other belts on?
Advice appreciated. Dave.
Dave
1986.5 Manual Blk/Blk
Old 07-20-2013, 09:55 AM
Crumpler's Avatar
ok, went for it.
How do I say this with out looking like a fool...worked better in neutral.
Belt was loose. Appeared in good shape otherwise.
After tension adjustment.
Dave
Old 07-20-2013, 02:07 PM
harborman's Avatar
I did my TB 2 years ago and now have 20K on it. I never had any warning light come on at any time.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-20-2013, 03:13 PM
harborman's Avatar
Also, if it sat and not driven for a long time, the belt may have stretched in places. Also, your tensioner may not be working correctly. Did the shop check it out at that time? I think you need to do the new belt and associated parts.
1986 928S
32 valve engine
Old 07-20-2013, 03:28 PM
Crumpler's Avatar
I took her out today and no issues.
I don't know, bottom line the belt was loose. Maybe shop didn't re-tension well enough the first time after previous install?
I have TB and WP being shipped, I'm going to change them out anyway.
I know how this will go over,but I decided to rebuild the stock tensioner rather then add the Porken system. I'm just not there yet, but then again I don't use a smart phone either.
Dave
Old 07-21-2013, 04:04 PM
Petie3rd
Mrmerlin's Avatar
for the tensioner rebuild you need some things,
a new gasket ,
a new rubber boot ,
and new piston O ring,
and new rubber boot clamp.
I suggest to use Hondabond 4 on the gasket,
clock the inner clamp so the open side faces up,this will reduce the chance of leaks
then the outer clamp is set while looking at the boot will get set to 11 O clock,
fill the tensioner with STP oil after it sets up,
not motor oil or gear oil,
Use a visene bottle with the tip driller a bit bigger to fill the tensioner,
fill from the hole furthest from the crank,
and watch for the oil frome the hole closest to the crank
also use the WSM to verify that you have the washer stacks correctly placed,
and make sure the washer thats on the piston/ rod/ spring is also correct
Old 07-21-2013, 08:47 PM
Yellowb1rd's Avatar
Oil-filled OEM units.. yuk!
Old 07-21-2013, 10:20 PM
Crumpler's Avatar
My only defense is that I talked to Carl Fausett first, and he has never had a stock tensioner fail, even with some of his engines pushing 900 HP. Since this is all learning for me, I also wanted to get in there and take it apart and put it back together.
Dave
Old 07-22-2013, 07:18 AM
Crumpler's Avatar
a new gasket ,
a new rubber boot ,
Stan, thank you for the tips. I will be sure to do that.
Also, thank you and everyone else as well for previous help. As a new guy, it really has made a difference.
Dave
Old 07-22-2013, 07:52 AM
928: Serial Enabler
I like a plastic syringe, like from the feed & seed store, to fill.
Old 07-22-2013, 03:44 PM
Petie3rd
Mrmerlin's Avatar
the syringe works good if the radiator is out of the way,
you dont wannna use the pump oilcan,
as you can unseat the inner boot clamp and blow the oil out of the tensioner
Old 07-22-2013, 09:00 PM
928: Serial Enabler
On mid year cars there isn't an interference problem with radiator.
You're right, I don't use the syringe to pressurize it.
Old 07-23-2013, 03:07 AM
