MPDano's Avatar
Originally Posted by 81headache View Post
will try rocker swtich and get some pics of engine
Cool
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-23-2013, 05:54 AM
ok fuel pump comes on and seems to be working my friend the mechanic says he thinks its possibly not getting a pulse to fuel injectors I have already replaced the fuel injector relay any ideas why else they wouldnt be delivering fuel
Old 07-23-2013, 07:47 AM
MPDano's Avatar
L-Jet for sure.
Old 07-23-2013, 07:53 AM
MPDano's Avatar
buy a noid light at the local auto parts store to verify injectors are getting the power. If not, Green Wire is in your future.
928 International-Distributor Wire 78-84-green
Write up is in the "Common Fixes" Thread.
Old 07-23-2013, 07:55 AM
why so expensive
Old 07-23-2013, 08:13 AM
MPDano's Avatar
why so expensive
One word: PORSCHE
Old 07-23-2013, 08:14 AM
thanks appriciate the help will keep posting results
Old 07-23-2013, 08:20 AM
MPDano's Avatar
Also the Noid Light tester is pretty inexpensive and they come with adapters to fit all size injectors. I think I paid less than $10 for mine at Autozone.
OEM/6 pcs. noid light set (27161) | Injector Signal Tester | AutoZone.com
Old 07-23-2013, 08:30 AM
so green wire will prevent injectors from firing
also has anyone succesully rebuilt this wire as money is an issue at this time in project just wanna get running and get it home
Old 07-25-2013, 06:22 AM
MPDano's Avatar
It's been discussed and supplies researched. In the end, just buy the one I posted.
Sometimes, and very rare, someone might have a spare used one that works. At least to get you home.
Old 07-25-2013, 06:54 AM
Recovering dismantler
neil30076's Avatar
also has anyone successfully rebuilt this wire as money is an issue at this time in project just wanna get running and get it home
Signal on green wire tells the control unit the engine is running, this signal triggers the injectors; check the connector at the ecu end of the wire, that is the one farthest from the distributor, by the 14 pin. If you are lucky, its falling apart and you can make a temporary repair there - pull the pins carefully out of what probably is a very brittle connector and insert into the other half. Make sure you match them pin for pin. If the cable is brittle or broken you are s****d, time to but a new one.
Neil
81, 86 928 widebody.
1929 Model A Street Rod 270hp, V6
Land Rover Discovery
Bayliner Ciera 2655
Old 07-25-2013, 07:37 AM
You cant have just one.
1982_928's Avatar
..Does it have enough gas in it? (I know this is a different car, but still...) My Mercedes 190e would start and run for a second, and die.. It had just enough gas in it to start for a second.
I decided to check how much gas was in it after I bought a fuel distributor and fuel pumps... Damnit.
How long has it been sitting at this shop? How rotten does the gas smell if you pull the gas cap and take a whiff?
Jonah Boyd
78 928 5 speed
82 928 auto
83 928s auto
74 260z 4 speed
Old 07-25-2013, 09:33 AM
my green wire should be here today and possibly installed tomorrow keeping hopes up and fingers crosssed
Old 07-31-2013, 05:29 AM
MPDano's Avatar
Use the common fixes thread pics as a guide. There will be a piece you'll need to remove on the Disty end of the wire. Take your time on this.
Old 07-31-2013, 05:58 AM
ok green wire installed still only starting and running for a couple seconds on starting fluid gonna check to make sure fuel is getting to injectors later today any other suggestions i can hear the fuel pump come on when i turn the key
Old 08-02-2013, 06:53 AM
MPDano's Avatar
Noid as already suggested.
Old 08-02-2013, 07:11 AM
sorry didn't see the noid before what is it
Old 08-02-2013, 08:03 AM
MPDano's Avatar
Tells whether your injectors are getting power. No power, injectors wont let fuel through.
They will blink while cranking.
Old 08-02-2013, 08:08 AM
hooked noid sensor up and we are getting no light there is power getting 12volts to injectors but no pulse to fire injectors. there is also fuel in the fuel rail and i already replaced fuel injector relay any ideas where to go from here
Old 08-02-2013, 10:30 AM
MPDano's Avatar
Have you gone through all your grounds? I believe there is a chart in the common fixes thread. Verify all the other injectors with your noid
Old 08-02-2013, 11:01 AM
Tags
81 928 wont start
