engine removal
hi I need some feedback. I have a 79 928 bad engine. great 5 spd. I want to remove the engine and transmission .where should I start? this is not a chevy nova. that would be easy. thanks
Old 07-24-2013, 11:44 PM
Engineer of profanity
924CarreraGTP's Avatar
There is no easy way. If you have access to a lift the easy way would be to drop the whole drivetrain out from under the body. Then separate the engine from the torque tube and transmission. It would save you lots of time and headaches. You'd still have to disconnect brake lines, hoses, linkages, and the shifter. The exhaust will have to come out first.
Disconnect shock towers, suspension front and back, unbolt the cross member, and the rear axle assembly. Lift the body up and off of it.
Most other people will tell you the long drawn out way of disconnecting the engine from the torque tube from the bottom, and then pulling the engine up out of the front. I say why not just drop the whole thing at once. I've never done it with a 928, but I've done it with 924's and 944's. When you drop the whole thing you can make sure that it all goes back together to specs as this is how Porsche built the cars in the first place. You should put a new clutch in it while you're in there.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 07-25-2013, 01:26 AM
928 Junkie
medipedicman's Avatar
Where are you located and what is your end goal?
Brian Phillips
1979 928 , 5-speed, cork interior
1982 Euro S 5-speed project
1985 928S, auto(sold)1978 Euro 5-speed (found another home)1983 928 s 5 sp short shifter black/black (sold)1982 928 auto (sold)
Old 07-25-2013, 05:38 AM
1982_928's Avatar
I see no reason to pull the transmission with the engine..... That just makes it harder. I'm about to pull the transmission out of mine again, and I can assure you it's no fun. Don't you hate it when people sell you something saying it works, and it doesn't?
There are 4 bolts holding the bell housing to the engine, and 6 holding the flex plate to the flywheel. Label and disconnect all the electrical wires on the engine, hoses, ect.. unbolt the motor mounts, bell housing bolts, pull the dust cover under the flywheel, flex plate bolts, and yank it out.
If you don't have a cherry picker, harbor freight sometimes has them for $99.
A bit off topic, Brian, did you go to the college when the power tour came through Chattanooga? I didn't see any 928's on the trip.
Jonah Boyd
78 928 5 speed - #111
81 928 5 speed - the "Copper Turd"
81 928 Auto
Old 07-25-2013, 10:51 AM
Pete R's Avatar
OP WANTS to take them both out, and he has no flex plate, it's a clutch.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 07-25-2013, 08:00 PM
1982_928's Avatar
Must have read over the part where said he wanted to pull the transmission too...and the part where it was a stick. My bad.
Sorry 'bout that!
Jonah Boyd
81 928 Auto
Old 07-25-2013, 11:28 PM
