-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   outside temperature sensor reading -40 censius??? (http://forums.pelicanparts.com/porsche-928-technical-forum/762254-outside-temperature-sensor-reading-40-censius.html)
Big Load 07-22-2013 08:42 AM
hi
i've been away and busy as usual with work things so never had much time to work on my car.
so far i have had the MAF changed, timing belt and water pump changed, flex plate checked and adjusted. now i need some help on the following:
1. I noticed on my dash the outside temperature is reading -40 !!!!!??:eek: whats up with that.
can someone please explain is this sensor just sensing the outside temperature or does it do anything special ?? the fact that it is reading -40 i think it means its working ?? maybe
2. Also i need some help in finding some screws for the front spoiler and wheel arches. does any one have any i can buy from them or let me know where to buy them from. I have been looking but cannot find them except with porsche.
3. is the steering supposed to be heavy to turn? mine is tight and squeeks a bit.
and obviously please if there is a thread regarding these points pls direct me to them. thanks
Big Load 07-23-2013 11:43 AM
why would you want to know the outside temperature anyway???? unless its linked to something
Big Load 07-25-2013 04:14 AM
i had to link this guy into our threads he is very good at helping diagnosing issues and his videos are idiot proof so far.
https://www.ericthecarguy.com/kunena/index
check him out if you ever need any help
