928S/4 cooling fan
My 1987 928 cooling fan, one of two, is not working. Not sure yet if it is electrical supply problem or not.
If this unit needs replacement are the OEM replacements the usual repair, or does it make more sense to upgrade to fans with more CFM. This is a street car located on the central part of the east coast in Delaware.
Also any advice on method for replacement would be greatly appreciated
dlp
Old 09-08-2013, 07:20 PM
Petie3rd
Mrmerlin's Avatar
read up on this link look for 928 cooling fans 87 on
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0CE8QFjAF&url=http%3A%2F%2Fwww.928gt.com%2FT-WallyHVAC.aspx&ei=fTktUr-2Ce_eyQGz5oG4DQ&usg=AFQjCNELPje_Z70T6sJEBQqPzEyL0qCDLA&bvm=bv.51773540,d.aWc&cad=rja
Old 09-08-2013, 08:01 PM
Just what I needed.
Sure wish I could print this out to use while working on my car.
Many thanks
Donald
dlp
Old 09-09-2013, 09:30 AM
needs new tires. Again.
fraggle's Avatar
The fan output stage is failing. There are ways to fix it but it is easily destroyed on disassembly.
'87 928S4 5spd - Owner
'85 930 EURO - Caretaker
Old 09-09-2013, 05:18 PM
fan
Thanks for the reply.
Where is the fan output stage located and what do I check?
Donald
dlp
Old 09-10-2013, 11:59 AM
928-Electrics Guy
Alan in AZ's Avatar
Whoa! We have no idea what is wrong....
It could be one fan is dead, did you check the fuses already? or it could be the output stage...
Since the remedy options are very different between these- it would be best to figure it out first.
If the fans are OK and its the driver you have one set of options - if the driver is OK and a fan is dead you have another set...
Alan
1994 928 GTS Black/Black Manual
Old 09-10-2013, 03:10 PM
checking
Alan
First thing I did was to check fuses. Using the on board check in the fuse box. Hope it is reliable. Not sure where the out put stage is located. Could you help with location and diagnosis
thanks Donald
dlp
Old 09-11-2013, 05:57 AM
Petie3rd
Mrmerlin's Avatar
check the two thinner red wires connected to the battery + terminal
Old 09-11-2013, 07:42 AM
