Help - No Oil Pressure on start up
Help,
I'm getting zero oil pressure on start-up - after about 10 seconds it comes up fine ? Every thing I've been able to find on this suggests the OPRV sticking open. So, removing it to check it out and see what I can find - cap off spring out (looks fine), but how do I remove the piston from the bore ? Any help much appreciated:-) Cheers Al |
80 928
Any weird or disconcerting noises at startup?Have you considered that your Oil pressure transducer (sensor unit) may be malfunctioning? A mechanical gauge in parallel with it could verify.
Good luck, -Kerry |
Petie3rd
helpful to include the year BUT
more than likely is the oil pickup tube seal inside the pan has failed, thus it takes a while for the pump to suck enough to supply , remove the pan and replace this seal first
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 09-19-2013 at 03:24 PM.. |
Problem History -
Hey Oz - Could you give us a little background on how the problem began ? Have you had the car very long ? What is the year ? Has this been an on going issue over time or just a recent development ? Did you change your oil (brand/viscosity) and the oil filter (correct type) just before the problem began ? Have you eliminated a defective oil pressure sending unit by connecting up a mechanical pressure gauge ?
The older style (piston cup/spring) oil pressure relief valve can stick open slightly from hardened varnish or particles of crud in it's bore. Normally the piston does follow the spring out during dis-assembly but if it is stuck inside the oil passage there is an expanding tool that you might use to fish it out. On one 80 model 928 it took a combination of multiple doses of carburetor cleaner and much perseverance as well. In a pinch I've heard of some using a wooden dowel pin that was trimmed down to just fit inside the piston and gently twisting it out. Here is a brief overview of the 928 oiling circuit - http://www.justanswer.com/porsche/5vdcg-porsche-928-no-oil-pressure-1978-928-removed.html Good Luck and keep us posted, Michael
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" Last edited by JK McDonald; 09-19-2013 at 03:46 PM.. |
