1980 Porsche 928
Brakes not releasing pressure. 1980
I have replaced the M/C, all 4 calipers, all the rubber hoses, and removed the proportioning valves. Yet they still don't release pressure after you drive for awhile.
Petie3rd
what fluid di you use ATE super blue or ATE Gold
/ What was the condition of the MC new /used? try unhooking the booster line, and plug the hose, yes run without boost assist , you may need a new booster
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
1980 Porsche 928
I just used regular oriellys brand dot 3 I believe. I did run it with the line plugged and unhooked. It did not seem to solve the problem. The M/C was brand new and I took it off to make sure it was properly installed. And then put it back on. I came to the conclusion that it was the proportioning valves. So I removed those. Still did not fix the problem. Anyway it could have been a falty master cylinder? I'm really pissed because this is the one thing from stopping me from driving it.
1980 Porsche 928
Any ideas?
Petie3rd
where did you get this MC and why not use ATE brake fluid in a brand new part
1980 Porsche 928
Some mechanic bought it for me I'm not sure where he got it. I've never heard of ATE?
Recovering dismantler
ATE -*ATE Brake Fluid Some mechanic !!!! Is he a Porsche 928 expert or a " all european cars worked on expert". If that part came from CardOne or a chinese owned shop in LA that rebuilds them - toss it and get the right part - they are junk. Listen to Stan (Mrmerlin) - you will never get this solved by just trial and error...
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach Last edited by neil30076; 10-16-2013 at 12:27 PM.. |
1980 Porsche 928
Some European car mechanic. Biggest mistake I ever made. Found a really nice 928 speciallist close by and he helps me out with a lot of stuff. I'll find out where the M/C came from. Should one drip fluid when it's just sitting on the bench? I noticed this one doing that, and Oreillys said it was normal.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
1980 Porsche 928
Guy said M/C was ATE brand and they got it from a supplier called worldpac?
loosen the wheel lines at the master - if fluid drips out and the brakes release then the master might be suspect - it could also be the pushrod from the pedal is out of adjustment and is too long and not allowing the m/c piston to retract enough to release the pressure
84 928 S - SOLD 2012 Cayenne S |
1980 Porsche 928
I adjusted the push rod all the way so it has tons of play in the petal to see if that was the problem. Did not solve it.
Did you re-install the proportioning valves? Without them you will never get the correct brake operation, You do have the WSM's? Vol 4, Section 47 is your friend right now.
1980 Porsche 928
No I got rid of them I believe. It was doing this before I got rid of them.
1980 Porsche 928
I do not have the workshop manuals. Still have to purchase those
Petie3rd
there is another adjustment though not usually used.
before you touch it loosen the nuts that hold the MC to the booster and remove and plug the vacuum line, drive the car see if the brakes are still sticking the adjuster is inside the booster but like Ii sai d this isnt usually adjusted. World pack is where Roger gets his parts so you should have gotten a good part I would only use ATE gold or Blue fluid in a brand new MC
Damn! I would've liked to have that valve.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
