Crumpler's Avatar
Rear Boge Replacement
Hey all, was changing original Boge sport shocks and replacing with stock Boge shocks. It doesn't look like I will ever track the car, so from cost analysis I went with stock.
My question would be does anyone have a trick to get the threaded adjustment sleeve off the used shock?
Also, the conical rubber support was distorted and relatively trashed. The picture doesn't really do it justice.
This is 928 333 043 00 in my PET diagram.
Roger seemed surprised and mentioned he had not heard of one failing before. Has anyone else come across this?
Dave
1986.5 Manual Blk/Blk
Old 11-08-2013, 03:15 PM
Dadddio's Avatar
I drilled a hole in one end and drained the oil.
Then cut the old shock in half.
That seemed to be the best way for me.
Did you get new shock bumpers?
Mine were toast.
Old 11-08-2013, 03:55 PM
Crumpler's Avatar
Thanks Chris, that is a good idea.
Yes the bumpers where toast as well.
I can't wait to see driver's side...this was the good side.
Dave
Old 11-08-2013, 05:15 PM
Network Native
Danglerb's Avatar
$50 each and they might need to be visually awful before some get replaced. Rear shocks tend to last much longer than fronts, so might be a neglected part. One of those parts you might replace if you had ordered it with the shocks, but now that it looks bad and you are ready to put the car back together you skip type things.
Old 11-09-2013, 01:59 AM
My trick with the threaded sleeves was to call 928 Int'l and have the send them to me. Wasn't worth the time for me to try to remove them. They told me at 928 Int'l that they shock them in solvent for 24 hrs and then use a press to remove them. Good luck. Shocks and exhaust systems are about the two worse jobs on any car.
69 911 2.3Ez
85 928S
Old 11-09-2013, 07:41 AM
I bought a pair of "new"bump stops off ebay that look suspiciously like the ones in your picture
I could not even guess how old the stock was, but after a month in garage, NO DRIVING!! just jacking car up and down, I decided to put in new springs, a quarter of the "new"bumps had turned to dust- looked like a cleaner version of your old ones.
test them somehow first, put them in a vise maybe- put them under pressure, see how they stand up.
Replaced them with some (red) energy suspension ones.
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 11-09-2013, 01:07 PM
Crumpler's Avatar
The Dadddio method proves successful! Minus whatever toxic goo I got all over the place, it wasn't that bad.
That's a big cup of PB Blaster with some holiday cheer.
Plexus, I agree, the new stubber seems flimsy for the job it is supposed to do. I'm going to look at other options, thanks for the heads up.
Dave
Old 11-09-2013, 05:43 PM
Dadddio's Avatar
Glad it worked out for ya Dave.
I mangled one on my first shock replacement.
The next three were pretty easy.
Still got one that's pretty roughed up that needs to be replaced.
Let me know if I can help.
Old 11-09-2013, 07:55 PM
A Wrench
SeanR's Avatar
Geezus, go to the local hardware store and buy a 2 ton press for $80.00. Saves you time and money.
'88 Supercharged and lots of other fun stuff.
Old 11-09-2013, 09:39 PM
curtisr
curtisr's Avatar
Amen, brother.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 11-10-2013, 06:47 AM
Crumpler's Avatar
Took a metal cut off, screwdriver, and five minuets per shock.
I guess I made eighty bucks.
Dave
Old 11-10-2013, 06:00 PM
Crumpler's Avatar
This was the culprit on the rear driver's side.
Notice how happy it is to stay compressed with no force at all on it.
I guess it's performance life was roughly 27 years.
Dave
Old 11-12-2013, 05:43 PM
Crumpler's Avatar
Better looking struts now.
Question: Is this the Factory ride height using quick method fender to ground?
27" Front
24.5" Rear
Dave
Old 11-15-2013, 07:45 AM
post on rennlist,
I know, I know. Dumb question re: Ride height - Rennlist Discussion Forums
It does explain(pic) where the rear points to measure height are,
then, the how to do it gets silly...... It goes into a description of bits of welding rod to meaure height, reminds me of when NASA spent millions to develop a pen that could write in zero gravity, the Russians just used pencils,
Get a simple tape meaure that has the length of case on it, lie on the garage floor , easy.
Who would have figured , using a tape measure to measure stuff.(you can also use it to measure bits of welding rod.....)
(the one I use has measurements marked that include the case, even easier for those that can't do the 1+1=2 maths
Old 11-15-2013, 05:13 PM
Crumpler's Avatar
Thanks again Plexus!
I'm definitely more of a soviet block thinker.
This was very helpful.
I can't remember who said stock Boge felt like a Caddy, but I think it might be true -- definitely a softer feel. It will take some getting used to.
Dave
Old 11-17-2013, 06:14 AM
Don't change the shocks, install heavier sway bars, keeps the caddie comfort, (Hard track day ride can get real tedious in a daily driver)reduces the roll on corners.
Old 11-17-2013, 06:54 PM
