-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   fuse Layout (http://forums.pelicanparts.com/porsche-928-technical-forum/780742-fuse-layout.html)
mayoman 11-09-2013 03:07 PM
fuse Layout
Hello, I'm a New Porsche owner and have a 1984 928. (its a project car) There are some very helpful posts. However I cant seem to find a diagram of the fuse panel. Also read about a 14 pin connector that I should clean. where is it located?
uBoat Commander 11-09-2013 03:22 PM
https://www.928gt.com/t-81fuse.aspx
mayoman 11-09-2013 03:29 PM
Awesome!!! That is exactly what I was looking for.
stepson 11-09-2013 10:02 PM
14 pin connector is on passenger side of engine compartment just behind the radiator and forward of the coolant pressure sensor.
soltino 11-10-2013 04:35 PM
Originally Posted by uBoat Commander (Post 7747480)
https://www.928gt.com/t-8384fuse.aspx
tino
MPDano 11-10-2013 06:49 PM
Now, print out those diagrams and put them in your glove box.
mayoman 11-11-2013 06:11 PM
all printed out! and thanks for the location of the 14 pin connector. Cant wait to get er running thanks again
stepson 11-12-2013 10:32 AM
Clean your grounds! All of them! You can thank me later for telling you now.
mayoman 11-14-2013 05:00 PM
cleaning all of the grounds starts this Saturday! I am on it!
Danglerb 11-14-2013 07:20 PM
Make sure you have the plastic cover for the 14 pin area that clips to the fender and goes over the jump post, which should have a cover too.
mayoman 11-15-2013 08:19 PM
I will check for the cover and report back on any progress.
