Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
firing order
I am looking for the firing order for my 84 928. I want to make sure the plug wires are going to the right place.
Old 11-10-2013, 04:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Petie3rd
Mrmerlin's Avatar
hey let me google that for you
porsche 928 firing order
NOTE you didnt specify 1984 Euro or US version so there are different diagrams
https://www.google.com/search?q=porsche+928+firing+order&client=firefox-a&hs=Byh&rls=org.mozilla:en-USfficial&tbm=isch&tbo=u&source=univ&sa=X&ei=_zOAUuniI6qtsQSj1oC4AQ&ved=0CCsQsAQ&biw=1023&bih=660
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 11-10-2013, 04:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Formerly from Bannlist
MPDano's Avatar
Isn't it on the cam covers or even on the underside of your hood?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior
Porsche928Forums.com (NOW Mobile Enabled!)
Old 11-10-2013, 06:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Sorry US Version as far as I know. Did I mention that this is my first Porsche? I'll Try not to ask too many dumb questions. Thanks for the Google tip! (that's how I got here) I guess I didn't type in the right key words! I will check the cam covers and hood too! Thanks
Old 11-11-2013, 06:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Petie3rd
Mrmerlin's Avatar
with more info your system looks like this
I also suggest to get the WSM DVD from Roger its the best investment you will make
Old 11-12-2013, 02:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Thanks for the firing orde. Now for another dumb amateur question... who is roger and where do I find him.
Old 11-14-2013, 05:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Petie3rd
Mrmerlin's Avatar
roger@************
best prices on the best parts
Old 11-14-2013, 05:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Pete R's Avatar
Is it running that bad?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 11-14-2013, 05:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I just got the care a few weeks ago. it is not running at all. very week spark. Im going to start cleaning all the grounds this weekend. I also got new cap, rotor, and plugs. When I replace those, I want to be sure they are right. when I attempted to start it I got a back fire out the air box. now I don't even get that. just a week spark. after all I have been reading, I am going to start with the grounds, move to the 14 pin connector, replace the rubber fuel lines and clean the tank. once I have those things taken care of I think we can start a real diagnosis. anything else you can suggest to do before attempting to fire it up again?
Old 11-15-2013, 08:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Network Native
Danglerb's Avatar
Cap, rotor, and plugs are all usually fine, coil, plug wires, ignition relay, ignition switch, dirty contacts the usual suspects.
Grounds, clean fuel tank, make sure all the rubber in the fuel system is good or just replace if in doubt. Good battery and ground strap, clean and reseat all fuses and relays, check fluid levels and condition, then look at next step.
Once it runs let it come up a temp a few times, then change the fluids. Don't drive without a good inspection of the brakes.
Old 11-15-2013, 08:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
MPDano's Avatar
Verify Timing by pulling off your timing covers.
Old 11-16-2013, 12:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Petie3rd
Mrmerlin's Avatar
if your car has a green wire to the distributor replace it if the connectors are crumbling or the insulation is cracked
its expensive but its usually the part that causes weak spark and other running issues,
if your getting a backfire then you have the wires crossed.
NOTE where #1 plug is to find #1 at the cap remove the cap and put the engine at TDC
the rotor will point to the hash mark in the dist housing
note the direction of engine rotation as well as distributor rotation
use a 27mm socket to turn the crank CW while facing the engine
Old 11-16-2013, 01:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
This is great Stuff guys! Thank you! list in hand. Lets see what I get checked off today!
Old 11-16-2013, 04:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
ok guys, my battery ground is lousy. someone before me replaced it with a round cable that is in poor condition. I know I need to replace it. where do I get the "Strap". Is this something I can have made? If I had a good cable made would that do the trick? I saw a few on ebay used. hesitant to buy used.
Old 11-17-2013, 06:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
stepson's Avatar
Roger has after market heavy duty flat ground straps.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-17-2013, 07:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Crumpler's Avatar
Cost was cheap too, 20-25 bucks I want to say.
Dave
1986.5 Manual Blk/Blk
Old 11-17-2013, 07:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
great I will order one up!
Old 11-18-2013, 04:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
