DZGunner's Avatar
Air Intake tubes
Does anyone have an alternative to the plastic air intake tube that go from the front air dam to the air box? I've seen some pictures before of 928 engines with different tubing, but no one has ever elaborated on what they are made of and such. My plastic tubes are old and have some holes near the bottom portion of the tube about halfway up.
I'm sort of a do it your-selfer (much like a lot of you guys), so if there's an upgrade out there that can be crafted with locally bought materials, i'd be happy to get some ideas.
Just so i can get a full spectrum of what's available, i'm not opposed to being shown aftermarket pre-made items.
Thanks guys.
1987 928 S4 - Guards Red
Old 11-16-2013, 07:35 PM
MPDano's Avatar
Strange that I didn't include the MB hoses I put on my Euro in the Common Fixes.
Part Number
1170940382
Genuine Mercedes
Air Intake Boot/Hoses; Intake Scoop to Air Filter Housing
1 per car.
$12.96
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-17-2013, 05:43 AM
DZGunner's Avatar
Where are you getting them for $12.96? and where did you get the colored hose to connect them? This looks really nice, thanks Dano.
Old 11-17-2013, 06:33 AM
MPDano's Avatar
Couplers are from eBay. You have to measure the tube diameter first once you get them. Google that part number and there are plenty of places, even here.
Old 11-17-2013, 06:43 AM
DZGunner's Avatar
What diameter coupler did you get
Old 11-17-2013, 07:01 AM
Fixer's Avatar
Looks great Leo, and good question and thread.
Matt Mariani, Philly Pa IG: matt_mariani_rsc
[B]1983 Super Carrera Coupe 'Mad Max'
1969 911E targa Crystal Blue / Black (selling)
1968 SWB 912 "Stinger 912R 1680 lbs
1977 911S coupe "Bandit" all original for now
Old 11-17-2013, 07:38 AM
Network Native
Danglerb's Avatar
Make sure you do a hole for the timing cover vent.
BTW I haven't ever gotten a good answer on which way the air goes through that vent.
Old 11-17-2013, 08:22 AM
Porsche 928 Fanatic!
Timing cover vent is to be connected to a vacuum to the intake - air comes out, it anotherwords, keeping negative/vacuum in the timing cover.
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 11-17-2013, 08:30 AM
stepson's Avatar
Roger also sells those MB tubes complete with holes and connectors.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Cobalt Blue 1989 S4 AT (The Blue Car)
Indishrot 1984 Euro S AT (The Stepson)
Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-17-2013, 08:45 AM
Kool
AirtekHVAC's Avatar
I got my replacement tubes on the 'bay....I think they were 64$ for a pair.....still in the box...
Ron
1978 5sp (#30) project-Wreckscue
1979 5sp Euro basket case
1982 5sp resto project
(Yes, I now have 3 project Sharks)
Old 11-17-2013, 09:19 AM
??? No fewer than 10 listings on e-Bay for the real deal air intakes made for Porsche, new,, $50-$60
Old 11-17-2013, 09:30 AM
DZGunner's Avatar
Thats for one though, two will cost atleast $115. Also, what is the significance of having the low air pressure in the timing cover? One of mine is messed up and doesnt exactly fit over the thing anymore, how important is that?
Old 11-17-2013, 10:26 AM
SanDiego928's Avatar
Leo - So nice. I bought the real deal 3 years ago but I like the looks of yours.
Mark
1981 928
Old 11-17-2013, 07:36 PM
stepson's Avatar
Roger sells both sides of MB ones for less than the cost of factory ones.
DZGunner's Avatar
I sent roger an email the day i made this thread, he hasn't replied yet though.
Old 11-18-2013, 07:03 AM
928_Trackie's Avatar
I am using 3" aluminum intercooling pipe.. And polished. It also removes the restriction in the middle of the plastic tube as it starts out as a 3" and is choked down to 2". I'm not using the vacuum port to the timing belt. I have run like this for 5 years with no issue.. And also if you look at a GTS, they were deleted. I'm positive the vacuum nipple on the timing cover has nothing to do with removing air pressure. There are many holes and slots in the cover for wire and such to remove any pressure, if any at all.
Old 11-18-2013, 12:42 PM
Engineer of profanity
924CarreraGTP's Avatar
I wouldn't think the air flow holes on the tops of the timing covers would hold any vacuum either. There would be tighter seals if so. I think it just provides a little more cooling for the timing belt. The holes in the timing covers probably blow more air out than it does suck it in. Maybe that's to provide a little more charged air to the intake. Maybe both, I'm really not sure. Also DZGunnar, if you stick your finger in the hole (don't get too exited) where the timing cover attaches, you can spin the sleeve in the inside of the intake tube. Then the holes of both pieces will line up and the intake tube will go back down on the timing cover.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 11-18-2013, 02:23 PM
Network Native
Danglerb's Avatar
Air intake tubes are pre air filter, ambient atmospheric pressure all the time. Mark Kibort is hooked up with those turbo efan people and they measured pressures all over the intake system, no losses pre filter, not much even post filter pre throttle plate.
Movement of the cam gears and belt will tend to draw air in, but flow path isn't clear, so flow direction at vent is still a guess.
Old 11-20-2013, 12:36 AM
Digging up an old thread I am getting a 1983 928 soon but it doesnt have the tubes. I have already ordered 4 of these. As far as fit at the back and front is it just push on or some other way of sealing as well.
Greg
Old 09-01-2018, 01:35 PM
stepson's Avatar
Greg,
They just push onto the airbox and also the cam gear cover vent hole.
Old 09-02-2018, 06:17 AM
