When I went on a maf hunt buying up some spares, I found zero that didn't need in most cases a full rebuild and new wire. Its a part that ages and slowly goes out of spec.
Neil, I wish you had posted your ideas on the forum instead of in a PM so we'd all know what direction you are thinking. Your ideas might help someone else down the line. Just a thought. :)
Cheers Neil |
That is a real good point Neil. I was just saying to possibly test his MAF into a known good car to verify that the MAF is an issue. He could send it out after that if need be, but you are right that there are much more technical tests available. Thanks for letting the rest of us in on your thoughts.
One thing I don't see mentioned yet. On the 85/86 there is a harness that goes to the Throttle Position Sensor (TPS) and these are known to go bad and when it happens, the car will exhibit these exact symptoms. It is located at the diagnostic connector at the front of the intake, it's a 3 pin connector and goes from there to the TPS next to the Y on the intake, beneath the runners.
Forgot to mention that those are being built and supplied by Roger as a complete piece. Good stuff so you don't have to tape or zip tie the old ones together.
Take pictures of stuff like that.
Does the MAF have a temp sensor in it as well as the hot wire? Or does it rely on the one in the air filter box? |
As to the MAF, if the wire is broken then you definitely do have an issue there. |
| All times are GMT -8. The time now is 06:40 AM. |
