Modified 4.7 project complete
Here is the final product of a year and a half project engine, Installed, and running.http://forums.pelicanparts.com/uploa...1390326164.jpg
Specs: -4.7us (M28-19) -Heads have Euro cams( .472/.432 lift) 3 angle valve job, port cleanup, new VG seals, milled .002 (surfacing) -All intake components cleaned, inspected, lubed (as applicable), spider and plenum epoxy coated -Full length tubular headers, Flowmaster Y-pipe, thru 3" tubing to a magnaflow muffler -Rebuilt clutch assy. -Ign timing set at 30deg BTDC @3000rpm BTW-Had excellent experience with a clutch rebuilder- Relined my disc's, they work excellent :) A special thanks to my wife for lending a hand as needed during engine Pulling/Reinstall, and for letting me spend money on other than Horsie stuff. Now on the the paint shop for quotes! -Kerry |
Looking great! But is that dust I see on those intake tubes?!:eek: http://forums.pelicanparts.com/suppo...leys/smash.gifhttp://forums.pelicanparts.com/support/smileys/ura.gif
-K |
That's great to see Kerry, keep us posted on the paint and the rest!-Matt
Could you post a pic of your y pipe configuration?
nice restoration project. Your intake looks great
FWIW I would swap out that fly catcher air filter for a factory part, The factory filter works better and gives 25 extra HP. Also use a fresh factory coolant bottle cap Roger has them |
Header Collector, Steel, Slip-Fit, 2.25 in. Primary Tube Diameter, 3.0 in. Collector Diameter, Each http://forums.pelicanparts.com/uploa...1390332818.jpg Essentially, I have tubular aftermarket headers, with 3" collectors, thru collector reducers to 2.25," thru the Y-pipe, thru 3" tubing to a Magnaflow 3" in dual 2.5" out muffler. (this Y-Pipe can also be used with your factory headers, but the down pipes will need altering). Note also I am not using a catalytic converter. If you have regular smog checks in your area, this setup may not fly. |
-Kerry |
I have MSDS on mine. I was curious if the flowmaster Y pipe angle matched the angle on which the collectors converge.
Great Job !!!! are those Also Euro Heads or just the Cams ? did the Cam require different Valve Springs / retainers . You in Las Vegas ?
I bet just the Cams are a big help and add lots of power on the top end |
BTW- I live n Pahrump..A little town 60 miles NW of Vegas. (I'm 15 minutes from the Spring Mountain Race track) -K |
The Euro Cam's you have Like increased compression / air flow / and the larger Valves as well as a lot of other things no doubt you know . intake lift exhaust lift intake duration exhaust duration 78/79 .435 .395 227 216 80/82 .396 .350 216 206 80/83 usa .435 .395 215 203 80/83 euro .472 .432 223 215 84/86 euro .472 .432 228 219 Here is a interesting Page from the net that perhaps you have seen already related Link to Page Re Cam Swap Euro Cam Swap I have a home in CA as well but am heading your way soon perhaps we shall meet at some point as we are somewhat Neighbors . anyway great Job on the 928 :) |
Nice work, another 928 back on the road.
Don't forget the cover for the jump post and 14 pin, the plastic shield that clips to the fender. Y merge looks pretty good for $44 shipped, I'm tempted to get one instead of letting the local guy "make one". Flowmaster Scavenger Series Collectors - Free Shipping on All Orders @ JEGS |
We need a video of it running. To me, looks a picture of a cleaned up 16 valver. Good job man!
-K |
-K |
<iframe width="1280" height="720" src="//www.youtube.com/embed/pWGsSco8RqU" frameborder="0" allowfullscreen></iframe> |
K http://forums.pelicanparts.com/uploa...1392082792.jpg http://forums.pelicanparts.com/uploa...1392082820.jpg |
| All times are GMT -8. The time now is 01:15 PM. |
