RE: rattle in sunroof
Hi Guys, my sunroof rattles when it is open, is there some kind of adjustment to be made for this problem. thanks in advance. Ed.
Nothing money can't fix on a Porsche, but could be something out of adjustment or a loose screw. If it bothers you I would try doing the normal periodic service to clean and lubricate and see if in the course of that you notice something obvious.
Yup, just sounds like something is loose. Here is a write up on when I disassembled mine, should give you an idea of how easy it is to take apart and put back together.
http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html |
Easy yes, convenient not so much.
I remember when I thought I was lucky that I got one with a sunroof... |
| All times are GMT -8. The time now is 01:12 AM. |
