mac30605
Radio wire connections '86 928
I have searched the forum but haven't found what I need. I am reolacing the stock radio in my '86 928 and can't firure out the wiring. I got an adapter to adapt the 8 speaker wires to 4. I connected those wires to the adapter, connected the ground wire, the battery pos. And the red lead to the ignition. But there is a small white wire that branches to two, one to the wires coming from the speaker harness and also alongside the antenna wire. What does this wire connect to? With all the wires connected, I get sound but only when the volume turned to max and very weak. It's an Alpind radio, any suggestions?
Old 02-16-2014, 03:38 PM
harborman's Avatar
I installed a new radio in mine a few years ago. As I recall, the radio speaker leads went to an amplifier in a Pod next to the passenger seat. I disconnected everything there and bypassed all as my JVC had the balance and fader in the radio. There was an antenna amplifier and it needs power so you need to make sure it's not disconnected. It helps to have a wiring schematic when making these changes.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 02-18-2014, 02:15 PM
