'80 928 injectors continually powered
I have a 1980 Porsche 928 with power at the injectors at all times. Can anyone tell me the cause, or where I should start looking to fix?
Injectors
I have a 1980, and although my problem was the opposite of yours, injectors would not go on at all, it turned out to be a relay. Possible that your relay is stuck closed???
Power should only be ign on, but its constant, brain switches ground to pulse.
Relay, ign switch, previous owner mischief. |
| All times are GMT -8. The time now is 05:22 PM. |
