1980 Porsche 928
1980 automatic Transmission slips
I recently noticed that the transmission in my 1980 slips when it leaves first gear (automatic Three speed-80,000 miles), just slightly. You almost wouldnt notice except for every once in awhile. This is the only time it does it. All other gears are fine. It then occured to me that I never changed or checked the transmission fluid (Car sat for about 15 years). Seeing how it is 0 degrees outside and snowy. Are there any shops that you would reccommend to get it changed quickly? I imagine you guys are against places like Jiffy Lube and I never take my cars there or anywhere really. However I have no time and it is very cold. Just looking for opinions or any type of help. Thank you
Old 02-10-2014, 07:13 PM
MPDano's Avatar
Yup, low fluid will do this. Get a tranny filter kit for your 3 speed and fresh Dex/Merc Trans Fluid. I use Castrol
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-10-2014, 07:44 PM
I've trained the guy at my local Oil Stop. What a PITA place to put the reservior. I have a slow seep & they offer free top offs so it works out.
Old 02-10-2014, 10:49 PM
Network Native
Danglerb's Avatar
It can be done, basically pick a shop that is convenient and train them to do it right. Oddly enough the lower down the food chain you start, as long as you are patient and persistent, the better luck you "may" have. You need somebody smart enough to learn how to do it right, but not so smart or experienced that they are sure they already know.
I'd also bring my own fluid and parts.
Old 02-10-2014, 11:19 PM
MPDano's Avatar
Buy a $5 fluid transfer pump is all you need to put fluid in the reservoir.
Old 02-11-2014, 04:23 AM
1980 Porsche 928
What is the procedure exactly? Does it need to be running or warm? Or do I just top it off
Old 02-11-2014, 01:26 PM
MPDano's Avatar
level and running temp
Old 02-11-2014, 02:15 PM
