Hump? What hump?
EugeneTheBeast's Avatar
Fuel pooling in manifold
Today while working on the car(84S) I had to remove the air cleaner base/airflow meter combo to have a look at some heater hoses. When I pulled it up, I noticed a bit of gas had pooled at the bottom of the orifice where the airflow meter fits into. What's up with that? I was working on it a couple of weeks ago and had the car running for about 30 minutes or so and may have left the switch on for a bit as well. Would a running fuel pump cause this? Relay sticking?
I can no longer sit back and allow Communist infiltration, Communist indoctrination, Communist subversion and the international Communist conspiracy to sap and impurify all of our precious bodily fluids!
Old 02-23-2014, 11:24 AM
928: Serial Enabler
At base of throttle body, inside at bottom of elbow? If so, common.
84,85,86 928 cars
Old 02-23-2014, 02:55 PM
Hump? What hump?
Yes indeed, and thanks, I didn't think it was a big deal but just wanted to make sure.
Old 02-23-2014, 04:46 PM
Petie3rd
Mrmerlin's Avatar
I think you mean a bit OIL had pooled ,
not gas
Oil pooling in the intake is normal gasoline OTOH is not
Old 02-23-2014, 05:50 PM
928: Serial Enabler
Generally its a mix on mine.
84,85,86 928 cars
Old 02-24-2014, 03:51 AM
Petie3rd
Mrmerlin's Avatar
Chris If your getting gas in the oil in the intake,
then you have a leaking cold start injector,
this isnt good as a backfire could possibly blow the intake apart.
I have heard of a few owners having the plenum blow off on an 85/86 32V engine it gets propelled into the hood leaving dents.
Usually its just oil sitting in the bottom of the intake
Old 02-24-2014, 01:16 PM
SanDiego928's Avatar
I remember when I took my intake apart. I found a light coat of oil. Always wondered about that. I was amazed how much debris is down in the valley surrounding that area from the last who knows how many years. Yikes.
Mark
1981 928
Old 02-24-2014, 05:26 PM
