Yellowb1rd's Avatar
Removing crank pulley bolt when motor is out of the car...
Pelicans,
Removing the crankshaft pulley isn't too bad with the flywheel lock when the motor is in the car. But when the motor is already out, there is no flywheel to lock on to. I was thinking of using my impact wrench, because that is the only way I see being able to remove that 218+ ft lb torqued (and most likely even more from years of not being removed) bolt with no flywheel to hold onto.
Anyone have any tips on how to remove this thing? I want to replace the timing belt, and what not before putting the motor into the car.
This is an '89 BTW
Old 03-05-2014, 09:00 PM
SharkHead
JhwShark's Avatar
I'm not sure about an impact wrench on the crank??
Any way to use/jurryrig (maybe with the centering tool?) a counter-hold on the backside while using a breaker-bar on the pulley nut.?
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 03-05-2014, 10:06 PM
Petie3rd
Mrmerlin's Avatar
use the impact wrench to loosen the crank bolt it makes life easy,
same goes for the flywheel bolts
Old 03-06-2014, 10:16 AM
Yellowb1rd's Avatar
Sweet. Thanks, mrmerlin. That's about the only way I see that I can remove this thing with the motor out of the car. It's a replacement motor, and wanted take care of the timing belt before shoe-horning it in there, because everything is so accessible right now.
Old 03-06-2014, 05:58 PM
Bob in Socal's Avatar
you will need flywheel lock to retighten though...
Old 03-06-2014, 06:00 PM
