88 S4 alarm delete help
In order to delete the factory alarm I connected the solid yellow with black w/red stripe. Are there ANY other wires that need to be connected together? Thanks
Old 03-30-2014, 10:41 AM
928-Electrics Guy
Alan in AZ's Avatar
Assuming the alarm module is removed and these are connected at the main alarm plug - that is all it takes to make it run.
This is also B23 and F25 on CE (you can also test there to see that they ARE connected). B23 should be on with the ignition.
Alan
1994 928 GTS Black/Black Manual
Old 03-30-2014, 04:49 PM
Thanx Alan I am just trying to figure out why it's cutting off after a steady idle. I did a complete refresh everything touching the intake
Old 03-30-2014, 05:50 PM
