928 instrument wiring pin listing
A strange request but Autofarm Porsche here in the UK pointed me in your direction.
I am building a one off " kit car" ( not porsche based I am afraid) but I want to use a 928 instrument cluster as it has a 170 mph speedo with electronic drive and a V 8 tacho - and it is a very high quality item.
I can buy one second hand here in the UK but I need to know which conncetor pin is for which item ( tacho, oil pressure ground etc.)so I can connect my own loom correctly.
I dont want to buy a whole workshop manual just for one connector list and I beleive it is in the VW logic style which may make getting a simple pin list hard.
Could anybody be so kind as to give me any suggestions or direction on the instrument cluster pin listings, I would be very grateful
thanks
Old 10-09-2002, 04:17 AM
Senior Member
Hello
Sorry nothing on hand but there are different MY with different connectors.
If you look close you will find the description from the posts printet onto the foil.
Grüsse
Old 10-11-2002, 01:28 AM
