-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   This is what happens when a tiny piece of metal gets stuck into one of your cylinders (http://forums.pelicanparts.com/porsche-928-technical-forum/812248-what-happens-when-tiny-piece-metal-gets-stuck-into-one-your-cylinders.html)
Yellowb1rd 05-20-2014 05:44 PM
...not for the feint of heart, gents. It ain't pretty. This is what happens when a tiny washer finds its way into your #3 cylinder after removing/replacing the fuel injectors. A very expensive error resulting in a replacement engine, and a valuable lesson learned not to be repeated. Worthy of tears, for sure.
After removing the heads to inspect the damage...
http://forums.pelicanparts.com/uploa...1400632390.jpg
http://forums.pelicanparts.com/uploa...1400632413.jpg
http://forums.pelicanparts.com/uploa...1400633085.jpg
928 Bro 05-20-2014 05:52 PM
That sucks. Hate to see that, feel for you.
Dean_Fuller 05-20-2014 06:31 PM
Ouch.....looks like coffee table material now.
Hope the new motor works out for you.
antsmands 05-21-2014 08:42 AM
That Sucks! Sorry for your loss!
Landseer 05-21-2014 04:20 PM
What is your location?
Danglerb 05-22-2014 06:09 AM
Nasty results, not that uncommon of a mistake. Head doesn't look "that" bad, so maybe just a shortblock and you are good to go.
Strosek Ultra 05-23-2014 06:12 AM
A number of years ago I bought an engine having exactly the same failure. Some red neck mechanic had dropped a nut into one of the cylinders when the car was at service. The block is now machined out for sleeving to 108mm bore. It will be a 7L stroker in time.
Åke
Fixer 05-24-2014 07:17 PM
Yellowbird,
Was this the first motor or the replacement motor you just purchased not
too long ago?
XLR8928 05-29-2014 09:37 AM
Ouch! :(
Yellowb1rd 05-31-2014 04:56 PM
Originally Posted by The Fixer (Post 8082032)
Yellowbird,
too long ago?
Apologies for not responding earlier fellas... BZ week!
This was the motor that I ruined (the original). It was easier to lift the motor out of the garage with the heads off, and I wanted to see the damage anyway. The replacement is already in the car, almost everything is hooked up, and nearly ready to start. If the replacement motor had that damage, I would feel the necessity to drive it off of a cliff, with the remaining seven working cylinders. LOL! This project has been a PITA, with too much time and $$$ spent.
Even harder to stomach. I inspected all the remaining cylinders and they were absolutely brilliant, with no scouring or wear whatsoever. It was a very strong and well cared for motor before the damage (caused by removing and replacing the injectors). Now it will become a table - a VERY expensive table at that, but hey, good art isn't cheap....
