what's this part called
hi there. there is a part that doesnt quite read correct on the ohm meter. i was wondering if anyone knows what this part is called and how it might affect the engine.
1982 US automatic -it's the brown part- -the picture is the front of the engine - http://forums.pelicanparts.com/uploa...1401619681.jpg |
I believe that is your "temperature time switch" for your cold start injector.
Double check the Manuel but I believe that depending on the temp the ohms reading can change just make sure your within range
I think some may be measured pin to pin, others pin to ground.
Not sure, but i think that one combines a thermocouple with a switch so you'll get some whacky readings depending on the temp and how you are measuring it.
| All times are GMT -8. The time now is 04:55 AM. |
