Tighten timing belt?
I'm posting for my brother. (1989s4)
He had the timing belt changed about 5 years ago at the dealership and at the time they told him to bring it back in after around 2500 miles to be tightened/checked. He finally hit 2500 miles after this years Hershey meet so the question is does he need to go back and get it checked out?
Kevin
Old 06-12-2014, 12:49 PM
Petie3rd
Mrmerlin's Avatar
yes the timing belt should have been checked after 1500 miles it gets checked cold and at TDC
Old 06-12-2014, 01:33 PM
Linderpat's Avatar
plus, the tension should be checked every so often anyway. At least once every couple of years. It should also be inspected visually very regularly. Easy to do - pull the venturi tubes and look in the holes at the top of the covers, make sure the belt is tracked into the center of the sprockets. Feel it underneath the covers for good tension as well (which is not a substitute for a real tension check by the way), and use a mirror to look around the area and up inside and behind the covers. Takes 5 minutes.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 06-13-2014, 05:34 AM
Ok, he will bring it back in to get checked.
Here's the subjective part, should there be a charge for this?
Old 06-13-2014, 07:29 AM
Linderpat's Avatar
sure. why wouldn't there be? Unless he paid in advance for it, the service provider gets to charge for the service provided. He can always DIY; just get the tool and study how to do it.
Ed
Old 06-13-2014, 08:35 AM
Petie3rd
Mrmerlin's Avatar
These charges should have been negotiated when the original belt work was done,
NOTE if he was bringing the car back to the shop that installed the belt,
then I would figure the charge for a tension check would be figured into the installation charge.
Thats what I do, all of my customers like this little freebie, even though they have already paid for it upfront,
it is also incentive for the owner to have the work checked after the new parts have had time to wear in.
Old 06-13-2014, 09:03 AM
tisilrad's Avatar
my timing belt warning light came on at about 1500 miles so the need to check it is obviously necessary. I had to retension mine..it wasnt off by much but it is scary when that light comes on on an interference motor:P
Heraclitus: 1987 porsche 928S4 5 speed black/black moneypit
Old 06-13-2014, 09:14 AM
I believe that's the case here. Thanks for the input guys, much appreciated.
Old 06-13-2014, 09:48 AM
Pete R's Avatar
Why at TDC?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-14-2014, 06:11 AM
Petie3rd
Mrmerlin's Avatar
Pete Per the WSM,
timing belt tension is checked with the engine cold and the timing set to TDC
Old 06-14-2014, 02:43 PM
Pete R's Avatar
Pete Per the WSM,
yeah, I know it says that but I was wondering the logic behind it other than to check the timing. Tension is tension, it doesn't matter where on the rotation it is, nor will an adjustment change the timing being that it's a toothed belt. I was just curious about it.
Neon SRT4 track car
Old 06-14-2014, 02:58 PM
19psi's Avatar
The cam sprockets will forcefully move on their own depending what position they are in. Test tension at a random location and you won't even be close. The alignment procedure is even in your Kempf tool instructions.
George in Indiana
928 Weissach #153
Cayenne S
Old 06-14-2014, 03:24 PM
Petie3rd
Mrmerlin's Avatar
thanks George
Old 06-14-2014, 06:18 PM
Pete R's Avatar
ahh, that makes sence
Neon SRT4 track car
Old 06-15-2014, 05:11 PM
