Johnny B's Avatar
Will a 928 4 spoke wheel to fit a 964
Hello All,
looking to fit a 4 spoke standard 928 wheel onto a 964 does anyone know if the splines are the same and this is just a simple fit.
thanks in advance for any help
Challenge your limits, don't limit your challenges
911 RSR Jagermeister replica (Sold)
1987 944 Turbo cup (Sold)
Old 07-08-2014, 07:19 AM
Pete R's Avatar
I dont what a 4 spoke 928 wheel is or a wheel spline but... The bolt patterens are the same, it will go on, the offsetts are quite different and the wheel will be further inboard on the 964, whether it will hit the shock or just look goofy I don't know
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 07-08-2014, 08:33 AM
honerboys's Avatar
I believe the splines on the steering wheels are the same - however you would need to check the collar where the wheel meets the column - I don't know for sure but these might be different in length - also you might need to swap the turn signal cancelling (plastic) tab - these are different for different models
84 928 S - SOLD
2012 Cayenne S
Old 07-08-2014, 08:46 AM
Johnny B's Avatar
Thanks guys appreciate the info
Old 07-08-2014, 08:51 AM
928-Electrics Guy
Alan in AZ's Avatar
Originally Posted by honerboys View Post
...also you might need to swap the turn signal cancelling (plastic) tab - these are different for different models
The plastic cancel tabs are on the switch side not the wheel. Check the horn ring (clock spring) type too.
I have seen the reverse transplants from late 911 to 928 so at least some years should work (these were probably all 993/996 versions), there is note of some mods required...
e.g.:
http://forums.rennlist.com/rennforums/11491070-post18.htm"]993 trianglular tri-spoke types
Be very suprised if they changed the spline types between years - spring types & horn attach may be different.
Alan
1994 928 GTS Black/Black Manual
Old 07-08-2014, 08:53 AM
