Ground Wingnut
Does anyone know where to buy the wingnut, a part number or recommend a similar solution for the ground cable connection.?
I have a bolt that keeps corroding, would like replace, thanks.
Old 08-10-2014, 05:34 PM
stepson's Avatar
Try 999 044 001 02 for the winged nut.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-10-2014, 08:25 PM
Linderpat's Avatar
...or just go to lowes or home depot. It is either a 6mm or 8 mm nut. I got tired of using a wrench to disconnect the ground strap, and switched to a wing nut from the local box store. Be sure to use a washer as well, to make sure you have a good surface area connection at he ground point.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 08-11-2014, 02:52 AM
Linderpat's Avatar
btw, you have a bigger issue if your bolt keeps corroding. Try to solve that problem - why is it corroding? Corrosion is caused by water. Do you have a leak in your hatch seal? That could lead to more serious performance issues - if the ground strap gets corroded inside the insulation, you won't know it but the car will run poorly or not at all.
Ed
Old 08-11-2014, 02:55 AM
928-Electrics Guy
Alan in AZ's Avatar
I agree - corrosion there is not that common - it will be caused either by moisture from a hatch/seal leak or by corrosive fumes from the battery box.
What is your ground strap round or flat? has the battery box lid been modified so it doesn't seal around the flat stock ground strap?
Does you battery have a vent tube to outside the battery box?
Alan
1994 928 GTS Black/Black Manual
Old 08-11-2014, 07:08 AM
Alan
I have a 6 month, good quality flat ground strap
batterybox lid looks ok
will replace the bolt, which bolt size and material would be recommended?
have use these guys in the past for various bolts.
Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
Old 08-11-2014, 07:59 AM
928-Electrics Guy
Alan in AZ's Avatar
The bolt material isn't that critical - just get the correct thread/length (ACE hardware carries metric). Most important is to clean the end of the strap (both sides), clean the ground point surface, use a washer on top of the strap. Use an electrical contact promoting final clean (e.g. deoxit/stabilant) before final assembly.
Once bolted together tight spray the whole thing with a light coverage of contact protectant spray.
something like this - many brands at local stores
Use it on the battery terminals too (after cleaning & connecting them) - This is not an electrical contact promoter - its a sealant.
BTW I'd still vent the battery outside the box to extend the life of your new ground strap
Alan
Old 08-11-2014, 08:23 AM
Thanks Alan, the cleaner and also protectant, will apply this time
Old 08-11-2014, 08:30 AM
i did a wiper delete a year ago, and the 2 bolt holes still look sealed, I do suspect moisture though, hatch bolts look the same.
Old 08-11-2014, 08:33 AM
Network Native
Danglerb's Avatar
Picture might help.
I bought a GAMA battery disconnect switch, and the bolt that came with it I think fit the ground point.
*** NOTE *** the metal around the ground point isn't very thick or sturdy, so don't wang on it.
Old 08-11-2014, 11:28 AM
harborman's Avatar
One other thing, you might want to replace the main braided ground strap going to the battery. Mine corroded inside the connection which goes under your wing nut. It looked fine but the inside was very bad and caused voltage drop.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-12-2014, 06:28 AM
928-Electrics Guy
Alan in AZ's Avatar
If you do find yourself frequently removing the ground strap - you could consider adding a disconnect switch right there - tight but doable.
Example
Alan
Old 08-12-2014, 07:14 AM
