gbgastowers's Avatar
help needed with tail light problem
My left tail light running light (small bulb second over from far left) won't come on and I get a tail light indicator on the dash. The car is an 82 Euro 928S. The housing was cracked so i bought a used one in good shape. When the new one is plugged in the same bulb does not work. I even tried an extra housing I had with the same results. All other lights in the assembly work except the running light. I tested the wires at the plug with a meter and I have power on the car side but as soon as the connections touch in the plugs to each other the power reads zero. All connections are clean and fuses are checked. Is it a problem with the bulb computer under the driver side of the dash? Alan are you there? Gunar
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue
Old 08-19-2014, 05:37 PM
harborman's Avatar
My original CWS computer was not working when I got the car, yet all my lights worked. I did replace the computer later and now all is fine. So my best guess is you have some other problem. How are your ground connections??
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-19-2014, 06:34 PM
cleaned them all about 3 years ago. I think the grounds are located behind the passenger quarter panel trim?
Old 08-19-2014, 07:02 PM
Patching into the working right running light was not the answer due to warning indicators staying on so I did more research. I removed and cleaned the bulb controller above the ce panel and that fixed the problem. Thanks for the help.
Old 08-23-2014, 09:54 PM
