How to replace Fuel filter?
Hi Guys, can you help me,! how can to replace the fuel filter, or show whit same pictures....
I had a 85 S, cat. 5 sped. American version.. TKS at all (I don't have a complete WSManual) |
Under rear of car is a cover on the bottom of gas tank. Remove that cover. Filter will be right there.
Tks. Dean _ I will doing it as you told me.
Regards. |
Do the 85's have a 2nd in-tank as well Dean?
Not sure...if there are wires running into the tank at the pump area then yes....if not...then no. I have read running with just one exterior pump will work fine. I doubt I will ever replace both again. Very pricey. I would just replace the in tank pump with the factory strainer and run just the exterior pump. But thats ME....
| All times are GMT -8. The time now is 12:12 AM. |
